Have canon mf5700 says check paper size and only prints one page of several page job
As above.Says change paper size. But we only are using a4
Exactly the same problem. Powering off doesn't help. Changing paper size doesn't help. Changing tray doesn't help. The machine says there is no print job in memory to be canceled. The computer says there is no print job.
  • 8 more comments
  • jacobsohnc Dec 29, 2007
    The printer sayd "check paper size" and then only prints one page of print job - Canon MF5700
  • z4m_84 Jan 30, 2008
    I have the same problem! But only happen when there is less paper in the tray??? - 25 sheets???
  • Rod_008 May 06, 2008
    When attempting to print gets error on display screen of the printer, "check paper size", "change paper size" "Cassette: LTR". I have changed all settings to A4, I have cleared all jobs, still same annoying error! Powered on and off, isntalled drivers on my laptop and connected, test page prints and then comes up with the same error noted above. HELP! :)
  • Anonymous Jun 16, 2008
    We have the same problem, check paper size. Please let us know how to fix this as we have tried but nothing is working.
  • Anonymous Jun 20, 2008
    la wea rara
  • Anonymous Aug 28, 2008
    changed paper size on machine and in computer, changed trays and powered off
  • Anonymous Sep 12, 2008
    same problem. nothing seems to work to clear it.
  • njoulay Sep 15, 2008
    red flashes saying check paper size and keeps printing one specific page continously
  • Anonymous Nov 26, 2008
    Same problem the fix discribed worked One further comment the green light bleow the Warning triangle sign was flashing this is the memory indicator light which tells you you have something waiting to print.
    The printer has a small button on the main panel, having a icon displaying an eye above it. Press that buton and you'll be able to cancel the curent print/copy/scan jobs. Just press that button then you can navigate with the "-" "+" buttons from the right (that small button is on the left) to select the job you want to cancel. Then press button "ok".
  • Anonymous Mar 06, 2009
    same
Go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Posted on Sep 21, 2009
Press that button "status monitor" on the left and you'll be able to cancel the current print/copy/scan jobs. Just press that button then you can navigate with the "-" "+" buttons from the right to select the job you want to cancel. Then press button "ok"
After cancelling the print job, open the cover and close the cover.
the printer resets and the error message goes away.
Posted on Jul 04, 2010
  • tomradi Jun 24, 2011
    This is the correct fix- Thanks
Unplug the printer and take outside,
Then blow the inside out with a airline
This solved the same problem with had with our printer
Posted on May 14, 2008
We have the same problem that happens when our guests print pages from various sources. Problem occurs when the paper size is listed as "letter". To solve you have to change it to "A4".
I also wish we could throw it away. Ever tried to cancel a 5 page print to avoid wasting paper? By the time you have gone through the many steps you need to cancel a print, your 5 pages are already printed. UUUUuuuuuurrrggghghhhhh, I hate it.
Posted on Feb 05, 2009
If you use OpenOffice and try to open document which is written on MS Work , have to go to Format->Page->
And check the Format Option. Have to be A4
Posted on Mar 14, 2008
  • Runaground Nov 16, 2010
    That's it. I use Windows 7 x64 and Canon MF 3110 printer.
    To fix this problem I go:
    1. Start -> Devices And Printers -> Right Click @ my printer -> Printing Preferences -> Set up paper size to A4.
    Maybe the step below was useless but I also set the same paper size in Right Click @ my printer -> Printer Properties -> tab Advanced -> Printer Defaults -> Set paper size to A4.
    Also, verify that your paper size in from printer menu -> paper params is also set to A4.
This is the worst piece of equipment I have ever purchased.
It has only ever worked about one-third of the time.
Useless.
I get
1 false error message that cartridge is low
2 false error message that paper size must be changed
3 printing the same page all the time
4 flahing red light
5 won't print
Posted on Feb 19, 2008
  • peterfaris Feb 01, 2009
    you must set all the programs that you print from to the papersize that you have installed - in my case A4
    You must alter the settings on Word, PDF, your web browser or any other program you print from.
    I always thought Canon were good - this is a terrible product and I would never buy a Canon printer again.
Have the sa me problem, but here is the way I figure out to solve it. The printer has a small button on the main panel, having a icon displaying an eye above it. Press that buton and you'll be able to cancel the curent print/copy/scan jobs. Just press that button then you can navigate with the "-" "+" buttons from the right (that small button is on the left) to select the job you want to cancel. Then press button "ok". This way I solve my mf5700 printer troubles.
Posted on Oct 30, 2008
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Canon W8400 printing.
Hi Did you get an answer I have the same problem.
Tony
May 24, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Have canon mf5700 says check paper size. Powering off doesn't help Changing trays does not help. After powering on again it prints a test page and then gives the warning again.
You need to remove paper tray, and unplug canon. Leave it this way overnight, and in the morning, reinsert the paper tray, and plug back it. This should effectively reset the machine, and clear that error. It worked for me!
Mar 06, 2009 | Canon Office Equipment & Supplies
My canom laserbase mf3110 print only one page
Well, when it comes to PDF files i found a solution. When u click the "print" icon, u get the "print" window. If u leave it as is, u will get a format/paper size error when trying to type several pages, as described by u. However, if u unmark the "Choose paper source by PDF page size", it will print as many pages as u want.
So...If u have trouble printing pages, it may work if u turn your pages into PDF format and follow the instruction above :)
Dec 20, 2008 | Canon MF3110 All-In-One Laser Printer
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
Canon MF5700 Series all in one printer
Throw it in the trash. It's a piece of shi*. I'm sick of mine.
Jun 25, 2008 | Canon ImageClass MF5770 Laser Copier...
MY CANON MF5700 PRINTER SAYS CHECK PAPER SIZE
Actionguy describes a solution where you: hit menu then # to get into service mode, scrolled to CLEAR, hit set, scroll to ALL and hit set again
You can also clear the printer's memory of the task that's causing the problem by pressing on the 'eye' button that gives the list of print/copy/fax tasks. press OK to select what kind of task you have, then choose your task to delete it. Finally press OK and Yes (minus) to clear it. Then, you can unplug the printer briefly to clear the error and it will start without the bad job and the error message.
Jun 19, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
IBM 4234 dot matrix
Sounds like the configured paper sized does not match the actual paper page height. So that when it does Top Of Form paper movement the paper stops slightly too low. Doing several form feeds should confirm this. If this is it then reconfigure the paper size to match the paper. Also measure to paper to see if it matches what you want it to be.
Mar 04, 2008 | IBM 4232 Matrix Printer
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Oct 16, 2007 | Canon imageCLASS MF5730 All-In-One Laser...
MF8180C Check paper size error
for god's sake don't ring canon customer service as they are useless and just keep directing me to their **** driver which is causing the problem. i could not convince them that my "printer properties" "paper available" was locked on "letter" and won't allow me to change it. even when i go to the "printer preferences" page and set everything to a4 and press "apply" it still is locked on "letter" in the "printer properties" page. Iv'e probably wasted about 20 hours on this and my office has nearly ground to a halt. If i knew it was going to be this much bother i could have just bought another brand printer.
Nov 27, 2006 | Canon imageCLASS MF8170C All-In-One Laser...
5,775 people viewed this question
k24674
jasbo
jasbo
