Question about StarTech.com StarView SV211K 2-port KVM Switch
Loads of channels on my starview box dont work. ive done countless automatic scans and it doesnt work, i only have random channels like TV 7 please can somebody give me some help :)
    Problem Solver:
  • 9 Answers
Need new key codes
Posted on Oct 03, 2009
I have a Eurovox EX7000hd, i tried to re-scan recently and its asked me for a PIN? Ive never set a PIN and have had no problems over last 6 months. Ive tried 0000,1004,1007 and 1648 plus many random ones....
All eurovox/starview and digivox boxes have been blocked from nagravision encrytped channels, this shows in different ways on different boxes.
Virgin has now switched to nagravision 3 encryption.
All eurovox/starview boxes can now only receive SOME free to air programs.
If you rescan, all the programs are picked up, but all the encrypted channels are blocked.
There is no fix yet, and there will probably be NO fix for your box, or any box without an ethernet connection.
Check afterdawn.com or techkings for more info
Sep 12, 2010 | StarTech.com StarView SV211K 2-port KVM...
Missing channels
Yes you have to call the service provider where they can fix this problem remotely. Joe
Mar 22, 2010 | StarTech.com StarView SV411 4-port KVM...
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
Lost channels
What I did after loads of trial & error trying t follow peoples advice on here so not sure how much of it you need t do (Stage 2) might not be neccessary so try 1) followed by 3) & 4) first ;o) :-
1) Deleted all the channels & reset the factory settings to 0000.
Turned off the box at the plug, left for a couple of minutes & turned back on
2) I reinstalled the software at http://www.4shared.com/file/76886028/fd4ac296/GTRom_the_box_Super_8102e_081129.html?err=no-sess (Not sure if thats necessary but I did so try this if 3 & 4 dont work without reinstalling)
3) Turned on the Box & went into the menu pressed 1570 on main screen to get into the CAS SASTEM & turned the EMU key ON
4) Reinstalled the channels using Telewest (Even tho I'm with Virgin) & voila, it worked & I can get all the channels again ;o)
Good luck - Stace
Jun 17, 2009 | StarTech.com StarView SV431USB 4-port KVM...
June codes - C&W starview box
Hi, got mine working, lions are winning
sometimes channels change frequency so they dont work,have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Jun 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Missing channels
You could try this mate.
Try this Menu--Installation-manual Scan-- Down Frequency 000000--Network Scan (R/L arrow)Disable wait a moment press OK. Channel should be at end of list.
Mar 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
No sky sports or sky 1,2,3 on the box starview 2
did you do a factory reset before flashing? do it then flash the box with the firmware. you will need to scan for channels and turn the emu back on after.
Jan 23, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Loss of starview channels
Try and determine the lowest transponder frequency that you can get a signal on.
Look at the frequencies you already have on the channels saved so far and choose the lowest.
Then in the installation menu select MANUAL SCAN and set that as the frequency.
Make sure you can see a signal and scroll down to Network scan and change to ENABLE with the Right arrow.
While still highlighted, click OK.
Scanning should then begin. It will say 1/1 to start with but should then jump up to 1/?? (the ?? being 2 digits).
Using this method indicated it scanned 56/56 transponder frequencies as opposed to 48 in Auto scan on one main provider.
Dec 10, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
156 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
