Question about Husqvarna Chain Saw 20" Bar
It becomes very loose and cover falls off - Husqvarna Chain Saw 20" Bar
  • 58 Answers
What becomes loose? If its the chain, do not use untill you have it adjusted!!!
Instructions should be in the manual if you are competant to do it.
Posted on Oct 03, 2009
I have a 1.5 amp charger for my bike it was dropped but now it shows its hooked up backwards and will not charge any help?
The fall caused a component inside to become loose or shorted, the only thing you can do is replace it.
Feb 06, 2016 | Schumacher Electric Speed Charge...
How can I tell if my harmonic balancer is bad?
If it has a rubber center, it can deteriorate and become loose, even fall off the crankshaft.
Jul 06, 2013 | Cars & Trucks
Only some letter keys work,all # keys work,Accer 5517 laptop
Kevin, it seems like the keyboard is bad on your laptop. If it has an extended warranty you should take it in for repair.
Did something spill on it recently or did it fall? Sometimes bumps or falls can cause connections to become loose and malfunction.
To gain access to your computer you can try a usb keyboard.
Jan 20, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Stripped Side Timing Cover
Too legal for me to get into - but I'm puzzled by the term "stripped".
The cover should be bolted to the side of the engine, and with several small bolts.
Unless the bolts that hold the motor mount to the block AROUND the cover were stripped for some reason.
It sounds like the motor mount bolts came loose and let the motor drop which would pull the axle out.
How they got loose is the question you can't answer.
They may have been "not tight" from the factory, or someone may have taken the mount off at some point in time to remove the cover.
The liability would fall on the person who caused the bolts to be loose which is another question you can't answer or prove.
Jul 06, 2012 | 2005 Ford Focus
There is looseness in the back cover when it is closed and there is gooy black stuff on the door where it seems to sit against the camera body
Stick black substance is probably the light seal the camera has along the edge of the door. Over time these foam like seal become stickey and start to fall apart. The same stuff is used as mirror dampening the mirror flips up when you take a picture. I think you can do a search on Google for an instruction to replace these deteriorating seals. I've had plenty of them myself on classic film cameras.
Aug 19, 2009 | Ricoh KR-30SP 35mm SLR Camera
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
My passenger side window doesn't roll up and it slides down into the door
Before the failure, did it make any knocking or griding noises? When you operate the button does the motor make it's normal noise? Did the window become loose and fall down inside the door abruptly? Some vehicles have issues with the "window regulator". This is the cabling device that hoists and lowers the window on the inside rail. Some automakers use plastic bits to keep the window on the rail. If those become loose or break, the window will fall off the tracks. Continued operation of the window will cause the regulator (cables, gear or motor) to fail. If you want to attempt a DIY fix, remove the door cover (a mechanic will usually call this a door card) and see if the window is off the rails. Good luck.
Jul 06, 2009 | 1999 Jeep Grand Cherokee
Toshiba A-135 Notebook only works with a charged battery but will not work with the AC Adapter. Is the system port bad?
It could be that the DC jack (what you plug the AC adapter in to) has become loose from the motherboard, or it could be the adapter itself. Plug the adapter into the computer, and -gently- move the cord, just a bit. Does the end in the computer move around a little? If so, you'll want to get it looked at.
If the problem is with the adapter itself, you'll need a replacement. I suggest calling up Toshiba and see about getting a replacement adapter. If the computer is less than a year old and falls under Manufacturer's warranty, any parts that you may need should be covered.
Apr 08, 2008 | Computers & Internet
Attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Feb 23, 2008 | Bamix De Luxe Hand Mixer
Husqvarna Chain Saw 20" Bar Logo
32 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
