Question about Motorola Mobility TracFone® V170 Cellular Phone
Pone frozen while on charge. displays charge
Pone frozen while on charge. displays charge complete. can't get any response.
    Problem Solver:
  • 14 Answers
Dont put it in the frezzer
Posted on Oct 03, 2009
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
My samsung completly frozen no response, how do i fix?
I suggest you can get the unfreeze code from Wickedunlock.com by specifying the country,locked network of Samsung Galaxy S.On entering that code you can unfreeze the phone.
Oct 31, 2014 | Samsung Galaxy S 4G Cell Phone
I have a Phillips GoGear Mix 4GB frozen.........
I had a frozen screen too just five minutes ago. I thought it was completely broken until I realised there was a reset button on the side of the mp3 ^^ Hope this helps
Apr 10, 2010 | Philips Audio Players & Recorders
My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Jan 20, 2010 | Sony E-reader Portable E-book MP3 Player
Screens Frozen Nokia 2760; Unresponsive
Your Phone software is Hang , and stuck it some time due to the loads of applications and msgs stored in cell phone , take out the mobile battery and re-insert , On your cell phone now check if you find the same problem , then you have to format your cell phone
Aug 18, 2009 | Nokia 2760 Cellular Phone
New GoGear Vibe will not turn on after first charge!
This is not a solution to fixing the mp3 player, but I no longer need assistance, I returned the product for a refund.
Jun 04, 2009 | Philips GOGEAR SA6045 MP3 Player
MP3 player frozen
the device is frozen needs a firmawrae upgrade in this case .
Feb 10, 2009 | SanDisk Sansa Fuze MP3 Player
My Archos 105 player has frozen with the off signal and the eggtimer symbol displayed on screen. I tried to charge it but it won't take the charge.
I left the player on for about 24 hours to allow the battery to completely run down. I then connected it to my computer and it took the charge and is working fine now.
Nov 05, 2008 | Archos Audio Players & Recorders
Motorola Mobility TracFone® V170 Cellular Phone Logo
65 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
