Question about Intel Motherboard
Three Long Beeps
Please is you know what the are the Three BEEEPS Its not video tried other then the onboard video with a PCI video card could be memory, but I switch slots in combinations Not sure where to look other then the Motherboard itself..
Any info on this would be great
Thank you in advance
My computer have a problem 30 second after long beep what is the problem
Posted on Jan 12, 2008
  • beltran1985 Jan 12, 2008
    my computer have a problem 30 second after long beep what is the problem thank you....
  • 167 Answers
Try cleaning the motherboard and the additional cards. Also try changing the RAM module(s).
Because you here the beeps...there should be nothing wrong in your motherboard.
Posted on Dec 22, 2007
Hello here is the ASUS homepage:
Here is a list of beep codes:
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
Monitor goes into sleep mode after turning system on. it beeps continually Compaq Presario
Sounds like the video card is bad...the system beeps to warn of a failure on the mainboard...if this system has onboard video then you may need to disable the onboard video in the bios and then install a pci video card..otherwise the motherboard may need replacing
Apr 25, 2011 | Computers & Internet
Problem with onboard video of a compaq sr2032x
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Apr 29, 2010 | HP Compaq Presario SR2032X PC Desktop
Replaced power supply on T2240 emachine now cant get onboard video" or any video,also tried PCI video card with no results. Need video to see if machine can boot
the fact that your not getting any video is that your computer is not booting or it can't boot right now.
might be best if you found someone to test and help you with it or if you took it to someone.
May 21, 2009 | Intel Computers & Internet
Problem with an deskpro pci graphic card
  1. with this age of computer it is still quite possible that the motherboard itself has a jumper that needs to be properly arranged to disable the onboard video.
Dec 23, 2008 | Compaq (1 MB) Graphic Card
PC wont boot, No beeps, No Bios, nothing
Faulty soldering on the motherboard, I have seen this so many times as of late...
Dec 10, 2008 | HP Pavilion dv6000z Notebook
Have Leadtek PX9800 GX2 on a Tyan S5397 Windows XP Pro X64. Not found at boot (long beep followed by two short)- no POST video from card or MB port, but operates when Windows boots. It appears OK in...
I think the video card is doing some conflicting on your system, so if you have a spare video card that you can try that will be better.
Hope that helps........
Jul 19, 2008 | Computers & Internet
PCI Video Card
The Specifications to your system states that you have Intel Extreme Graphics onboard. Below is a link where you can find manuals and drivers for that card.
Feb 23, 2008 | Insignia D400a PC Desktop
Add in Video Card
Yes 6 beeps indicates that there is no video card. Remove the card and plug into another PCI slot as some like to be the first PCI bus used. You will more than likely have to remove a sound card or some other interface do this plug in your new card into the slot and power on.
If there is still 6 beeps there are two possibilities
1 The Video PCI card id faulty
2 The Card is not compatible with your machine.
I do hope this helps you you also may check that you don't have to disable the card within the bios settings as sometimes even though the hand book tell you it should auto change sometime you will have to do this manually.
Thanks J
Jan 05, 2008 | HP Compaq dc7600 PC Desktop
Elitegroup k7som problems
check the memory card if the memory card is faulty the system would show no vga if u checked it the problem lies with ur mother board
Dec 02, 2007 | EliteGroup K7SOM Motherboard
Intel Motherboard Logo
271 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
