Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Sometimes, my Whirlpool washer drains water but does not spin. If I re-set it to the Rinse cycle, it will then go through the spin - most of the times. This is now happening more frequently.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Whirlpool Expert
  • 154 Answers
TIMER GOING BAD
Posted on Feb 07, 2010
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Washer will not finish its rinse or spin cycle
Check that water can drain out of the machine
1/ Check that the filter is not blocked
2/ Check drain motor is working (ie. not blocked with coins or hairpins etc)
3/ Check that pipe from tub to filter is not blocked (I had a sock blocking mine)
4/ If there is water in the filter and the drain motor runs then check that waste water hose is not blocked.
Aug 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Ultimate Care II Model #LSQ7030KQ0 Won't Spin
Either a bad lid switch or a bad clutch/brake on the transmission.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultima Wash II Intermittent Rinse/Spin
Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
79 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
