Question about Bosch Axxis WTL 5410 Electric Dryer
Dryer is louder than before
Started to add a deeper low frequency type noise than it had before. Any history of bearing trouble?
Took the dryer apart and it was filled with lint. Cleaned with vacuum and compressed air. The motor belt pulley was gunked up with hair etc and cleaned that too. Tested and reassembled. Still have the low frequency sound which I take to be bearing sound. It may fail in which case I'll replace the bearings but now the dryer runs much better. The dryer is about 10 years old but now looks like new. Was easy to disassemble so if I have to do it again no problem.
Posted on Oct 05, 2009
Why does my Frigidare crown dryer runs smooth when starts up, but gets a noise that gets louder the longer it runs it runs
Either your drum bearing or drum felt kit is worn out. It is always better to put drum bearing along with new drum felt kit.
Dec 05, 2014 | Dryers
My 2000 boxer 2.7 has 44k and has a howling noise that seems to be coming from the right front wheel, doesnt seem to matter if a/c is on or off. Only makes this noise sometimes when car is moving, at...
The type of noise you report is consistent with wheel bearing failure. It is VERY difficult to determine failure simply by lifting wheel, and sensing play or roughness upon rotation. My experience tells me that bearing start to fail with a high pitch noise ( no play) and at later stages with a deeper rumble, and a tad of wheel play. From start of failure, to absolute disaster, like losing munitions / bearings, it might take like a 1000 miles or more. At earlier stages bearings will howl only when provoked, and will stop whining if you add more weight, or take off weight from them, such as in turns or heavy breaking.
Jul 04, 2011 | 2002 Porsche Boxster
Loud squeaking noise when you start up the dryer could it be a bearing dull squeak not high pitched a little bit of a grind sound
It does sound like a bearing or at least a lack of lubrication. But it could also be belt slippage if it only happens at the start. If it is the bearing it would be continuous and slowly get louder and louder.
Jun 18, 2011 | Whirlpool LER7646E Dryer
I have a GE dryer that started making really load screatching noises. I took it apart and replaced the motor and the belt. It ran for a few minutes and started making the same noise. I am not sure what...
The idler pulley bearing might be the trouble. If the dryer has an idler pulley that tensions the belt, check this bearing in the idler pulley. If it is a bush type, just oiling it might be all that is required. Also make sure there isnt any piece of wire etc in the drum bearing. You might have to take the drum out to check this. However the most likely cause of a SCREACHING noise is the idler.
Mar 13, 2011 | Dryers
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
GE dryer is getting louder and louder - not a squeek just motor seems to be running louder
THERE ARE THREE POSSIBLILITY. THE BLOWER WHEEL IS LOOSE AND BANGING ON THE VENT. THE BEARING FOR THE TUMBLER IS BAD, MAKING A LOUD SCRAPING NOISE. ROLLER BEARING IS BAD. WORSE CASE, THE MOTOR IS GOING BAD. GOOD LUCK
BOYNISMO@YAHOO.COM
Jul 04, 2009 | GE Dryers
I start having a low frequency noise inside the car, like resonance, 2002 Jaguar X-type, after driving for sometime, noise changes with the speed, but won't go away when driving slowly, gets pretty loud at...
Could be one of your wheel bearings going bad- I've had to replace three of the four on my 2002 S-Type in the last two years. Raise each tire off the ground -- if you can wobble the tire with your hands, the bearing is bad. They shouldn't move at all if they are good.
Apr 16, 2009 | 2002 Jaguar X-Type
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Bosch Axxis WTL 5410 Electric Dryer Logo
104 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
