Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
My brother 490CW won't print black ink - Brother MFC 490cw Color Inkjet Multi-Function Printer
I HAD THE SAME PROBLEM, the printer started using all of my yellow ink.
Look at the black cartridge and check to see if the opening on the side is as it should be( a little ink is able to come out of it).
If not, then you need to replace the cartridge with another one.
This fixed my problem after a lot of wasted time with me trying to install the drivers again, which was not the problem.
Clean it a few times with the black only , then check the print, it may take 5-10 times.
Posted on Nov 27, 2010
SOURCE: Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Posted on Apr 16, 2009
  • 55 Answers
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Posted on Jun 30, 2009
komguy
  • 2306 Answers
SOURCE: black ink is not dispensing
There may be an air bubble in the black tubing, it will take several more cleaning cycles to clear. You can tell it to clean only the black and save the other inks.
Posted on Jul 01, 2009
SOURCE: Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Posted on Feb 14, 2010
crapiemael
  • 241 Answers
SOURCE: can you make the brother mfc-490cw print in black
Yes, go to properties for the printer, probably right click on the printer under printers, click on "printer preferences", and then click on "color", and change it to print in "gray scale". This will be black only. This may not be the exact way to do it on your system but look for the color setting under the printer and change to gray scale.
Posted on May 18, 2010
Prints out blank pages, won't test print, new ink, cleaned multi-times, still blank!
Silly question from my side: have you removed the tape covering the nozzles of the cartridges? Is it original Brother cartridges, or is it compatibles?
Aug 23, 2011 | Brother MFC 490cw Color Inkjet...
Hello again can i not clean the printer head nozzles myself? in my brother mfc 490cw out of warranty but was working previously until black ink ran out copying but they are blank pages all inks are full
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head. A Warranty does not cover blocked print heads.
Jul 20, 2011 | Brother MFC 490cw Color Inkjet...
I have to print a word document in black. Because I have no yellow ink, the printer won't print anything. I have tried everything and just want to print a simple one page document and I have plenty of...
here's a solution i came across when dealing with the same problem. apparently the printer expects all of the cartridges to be full and has a sensor to make sure they are even when only printing black. hope this helps!
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Jul 13, 2011 | Brother MFC 490cw Color Inkjet...
My mfc 490cw will not print black ink. What should I do?
Try to clean the print head 2-3 times,if not work you need to replace 100% the print head.If a have been usefut please give me a vote :)
Mar 14, 2011 | Brother MFC 490cw Color Inkjet...
MFC-490CW does not print black ink, what can i do to fix this?
does it print in any of the other colours? if not, it sounds like one cartridge is empty and the printer will not print until you have full cartridges.
Feb 08, 2010 | Brother MFC 490cw Color Inkjet...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Printer won't print black ink
From multiple online sources, this appears to be a fairly common problem with this model. As a matter of fact, my 490CW is experiencing the same exact issue. Called tech support and they're issuing an exchange. I'd advise that you do the same.
Oct 09, 2009 | Brother MFC 490cw Color Inkjet...
Black ink is not dispensing
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
1,086 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
