Question about Yard Machines Garden
Mower starts then acts like it is flooded is it
3 Suggested Answers
  • 45 Answers
SOURCE: lawn mower wont start possibly flooded the engine
make sure you have a good clean and dry spark plug
Posted on Apr 29, 2009
al_kupchella
  • 843 Answers
SOURCE: mower starts and runs but
Sounds like maybe the choke is stuck closed. If you remove the air filter the choke is the first butterfly valve you can see. The throttle looks similar but is a inch or so deeper into the carb, and you can't see that unless the choke is open. Try removing the air filter and starting the mower. It might run just a little better without the air filter since it will get a bit more air, but if the choke is stuck it still won't run right. But you will be able to see if that's the problem right off. If it runs great without the air filter, and the choke is not stuck, then the problem is a clogged air filter and you need to replace it. Good luck, Al K
Posted on Jul 26, 2011
When the mower deck is engaged the lawn tractor acts like it is choking out with to much fuel. I have to throttle down and usually it works fine again for about 10 minutes or so then acts up again.
If it's choking with too much fuel do you have a clean air filter? A dirty air filter will make it so no air can get in and make it flood.
Jan 15, 2016 | Garden
I have a craftsman mower that will not start has spark getting gas may be flooding what may be the problem model # 944.369720
if flooding with gas replace needle and seat in carb take plug out pull starter cord to clear clinder make sure no gas in oil pull dipstick find out ok put the plug back in then squirt some starting fliud in carb start motor up
Sep 14, 2014 | Garden
Husqvarna floods when starting hot
Your module is an electrical unit. Part of it acts like a breaker in a fuse box. A breaker over heats and shuts off when cooled it works again. Like a built in safety switch so you don't start on fire.
Jul 03, 2014 | Husqvarna Garden
I got my mower out the other day it did fine till I engaged the electric pto, it then died and I cant get it started since then. It is getting spark and is getting fuel. It act like it is flooded , I have...
If the fuel is set too high and the choke is on it is easy to flood it. The solution is to open the choke and keep the throttle low for a few turns to air dry the spark plugs then back to choke to start it again
Oct 16, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Ariens 21in classic is not starting, airfilter was drenched in gas and acts flooded, how can i fix that?
maybe it is drenched with fuel the needle and seats are having a hard time in the carbs sitting in the newer fuel we now have
Jun 09, 2012 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a troy built riding mower it starts up fine , runs 10 or 15 minutes, then it starts spuppering and dies. then it acts like its flooded when you try tostart it again. then the other day while tr
is it starving for gas the gas cap vent could be plugged keeping the fuel from flowing leave the cap loose and run it/are you loosing spark when this happens like the coil is going bad?
May 08, 2012 | Garden
The lawn mower ran out of gas and now won't restart. I tried starter fluid. will spark but not continue to run. Acts like it's not getting gas. Troy built super bronco. 3 months old
Remove plug or plugs and check them to see if tractor is now flooded. Clean plugs and check gap and reinstall. Check carb diaphram to see if it is totally closed or not. This will cause the motor to flood. Good Luck!
John
Sep 27, 2009 | Garden
Garden Logo
78 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
