Question about iiyama MA203DT 22" CRT Monitor
MA203DT monitor dead again
Hi I have a iiyama MA203DT monitor. About two months ago it went dead. Two days later it came back to life. It has gone dead again. It is getting power but when I press the on button nothing happens. Even the light is off. thanks
  • 2,229 Answers
I think it's trying to tell you something!
Time for a funeral. Best get a new monitor.
Posted on Oct 03, 2009
  • 6,993 Answers
Hello, welcome to Fixya!
Your monitor is having a power fault because it is not switching on. The monitor might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. If it doesn't power on, plug it into another outlet, to make sure there electric current entering into the rmonitor.
If plugging into another power outlet doesn't power it on then it confirms that the receiver is having a power fault.
When electric current comes from the power outlet into the monitor, it goes straight into the power supply board which then circulates the current into the unit. So if the monitor doesn't power on, the first thing is to make sure there is power entering into the monitor.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board. Once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect and solve the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Jan 05, 2012
Iiyama E2607WS just stopped working - completely dead - internal fuse OK
In most cases there are one or two capacitors in the power supply that open, and in some situations they have a bulge at the top making it easier to spot.
Apr 19, 2012 | iiyama E2607WS 26 inch Monitor
Hi I have a samsung syncMaster 920N The screen has suddenly gone blank - the power light is showing. I have a second identical monitor and have swapped cables but no difference Is it a repairable fault?...
This happened to me a few months back. I removed all cables and left it for 2 days. Switched back on on it worked fine. That is until yesterday when half the screen went black. I found that my driver was out of date. I have undated the driver but have decided to leave it off and unplugged for another day.
You could try this. You say you have another monitor, i would suggest using it for a few days and the try the old one again.
Dec 05, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Iiyama 19'' no signal no nothing. think its stuck in standby ??
Have you tried turn off computer unplug it remove and reseat video card. unplug monitor and repug it back in
Sometimes connections can need reseating
Feb 28, 2017 | Computers & Internet
Child went to the future, flowers now gone in the present
I'm very sorry but you can't get it back. I advise not to go in the future at all. The oly reason to travel time is to make Gulliver appear more often. If you do this, go back a couple days
Apr 03, 2009 | Nintendo Animal Crossing: Let's Go To The...
Iiyama HM903DT - Stopped switching on - constant orange standby
The way I solved it…
I received from iiyama a quote for repair: 400€ without VAT, 478 € with VAT, with a 3 month warranty.
So I ordered a HP LP2475W H-IPS LCD monotor from HP, for 656 € VAT & delivery incl. And a 3 year ON SITE warranty. It is superb, and after calibration it largely outperforms what I had before for my photographic use.
Hope this will help…
Jan 17, 2009 | iiyama Vision Master Pro 454 19" CRT...
DEAD IIYAMA AS4636D
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Laptop monitor problem.
if its under warranty which it should be take it back to where you purchased it it wont be worth repairing sorry.
Oct 29, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Went dead
Defect at your main board .
Oct 11, 2007 | Acer AL1706AB LCD Monitor
iiyama MA203DT 22" CRT Monitor Logo
139 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Ed Mac
steve morris
steve morris
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
