Question about Gigabyte GA-M61PME-S2 Motherboard, AM2, GeForce 6100/nForce 430 Chipset, Dual DDR2 800, PCIe x16, SA
DVD not recognised/IDE channel is not working
About a year ago my LG DVD-RW didn't appear in My Computer, restarting the computer solved the problem and I happily forgot about it..... then about 6 month ago same thing happened, restarting didn’t help, drive wasn’t recognised by BIOS, so I went inside the computer and after moving the jumper and reconnecting the IDE cable drive started working again.
Last week, the DVD-drive disappeared from My Computer and BIOS once again, and now i can’t get it back at all. I know for the fact that the actual drive is working, I connected it to a different computer and works perfect, also I tried connecting a different DVD-drive to my computer and it won’t show up. I tried changing the IDE cable and connecting it as Master/Slave but nothing is helping. Also I only have one IDE channel on my motherboard, hdd is connected through SATA.
Is this the sign that something is wrong with the motherboard? Could an IDE channel be dead?
Also other problem, maybe its related to the above somehow
From the very first day when i put up my pc together over 2 years ago, the USB’s weren’t working right. There are 4 USB connectors on the motherboard and only every second one works (second and fourth). The first and third are only working as USB 1.1 very slow. Also when connecting 2 front USB’s to the motherboard again only second one works. Could this again indicate that something is wrong with the motherboard?
Anyway all I am concerned about at the moment is to have an optical drive on my pc as i can survive with 3 USB’s.
Is there any way to check the functionality of my IDE channel, maybe some program. Or any other suggestions on how to fix this?
Thanks
PS. Also why do I have a 3.5 floppy in My Computer, even though I have never had it connected in my PC?
I want to download my ms 7184 driver for my pc
Posted on Oct 03, 2009
Not apearing on my computer
1.Install the driver disk that came with the drive.You can even download the driver from the internet from here-http://www.lg.com/us/computer-products/optical-media/LG-internal-dvd-burner-GH20LS10.jsp .
2.If the drive does not work still then check out the connections made in the system i.e power cable,IDE/SATA connector also check that the data cable {IDE/SATA} is not faulty.Heck the jumper settings See the drives user maunal to check for jumper settings or try to find the printed sticker/label on the drive
3.If drive does not works your drive is faulty hope this solves your problem..please don't forget to rate me ....
Dec 04, 2010 | LG SecurDisc 20x Internal Double-Layer DVD...
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
Dvd rw is not detected in windows xp in my toshiba a75 laptop
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > click on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and select uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 07, 2009 | Toshiba A75-S125 Satellite Notebook
Dru-190a sony it takes 50-60 min to write
Just right click on my computer, go to properties> hardware> device manager> IDE ATA/ATAPI Controllers. there u will find several primary and secondary IDE Channels. Right click on first IDE channel and goto properties> Advanced settings, change transfer mode to "DMA if Available". Repeat it with all the channels. If problem still persists then uninstall the channel containing ur DVD Writer and restart your computer. It will detect new hardware as DVD Writer. Now if it is showing the transfer mode "DMA if Available" by default then your problem is solved.
Dec 27, 2008 | Sony 20x Dvd Rw +And -Dru-190a Burner
My dvd writer DRU-190A takes 50-60 minutes for each dvd writing.
DVD RW Drive
Vista sucks. However, delete your drive and change the IDE cable. Also, put the drive onto another IDE channel so it re-initializes your drive - winodws data bases a drive when it has more than 5 DMA errors and clocks its speed down to PIO - very slow
Jul 22, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD dead??
EASY. TRY TO REPLACE YOUR OLD IDE CABLE CONNECTED AT THE BACK OF YOUR DVD. BUY A NEW IDE CABLE IT MIGHT SOLVE YOUR PROBLEM.AND LASTLY MAKE SURE THAT THE IDE CABLE IS WELL SEATED ON BOARD AND ON DVD.
Jun 23, 2008 | NEC ND-6650A DVD RW Dual Layer Burner
LG GSA-H42N 18x DVD RW DL IDE SOFTWARE
You can try using VLC Media Player (free)
WinDVD (free trial)
PowerDVD (Free trial)
or download k lite codec pack from free-codecs website
You should then be able to use windows media player 10 or 11 to watch dvd movies
As tratado uninstall el dvd en device manager ?
Para llegar a device manager press la llave con el "windows logo" i la letra "R" ala misma vez i luego en la caja que apareze escriba devmgmt.msc
despues busce el dvd/cd rom i pongale uninstall
restart computer
Nov 25, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD BURNER DISAPPERS FROM "MY COMPUTER"
You can try using the ide cable connector that the other drive is on and swap them round just to illiminate the cable connector, but at the end of the day i think your DVD burner is faulty and requires replacing, as they are very innexpensive to replace as you wili probably know,so don't waste too much time trying to solve it. The drives dont last as long as they used to because, keeping the price of burners down, like anything else means cutting corners and costs and in burners cases as was the case with PS2's the lasers are cheap and soon fail.
May 06, 2007 | Sony DRU-810A DVD RW Dual Layer Burner
Gigabyte GA-M61PME-S2 Motherboard, AM2, GeForce 6100/nForce 430 Chipset, Dual DDR2 800, PCIe x16, SA Logo
221 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
