Hotpoint wt 540 will not run All indicator lights are flashing e-mail derek.emery@talk21.com
    Problem Solver:
  • 14 Answers
I had a greyhound that would not run so i kicked him up the *** that did the trick
Posted on Oct 03, 2009
Hotpoint 6kg washing machine Aquarius wash light indicated door lock indicator flashing machine won't fill any ideas thanks Brendan checked filter ok
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Jun 04, 2015 | Hotpoint Washing Machines
Stay in high flats 4up low water pressure is there away of reducing the pressure in the hotpoint wt 540 washing machineso it will take in te water
If your water pressure is to high or even to low then just check the taps at back where hoses are fitted. Make sure they are fully open if pressure is to low, also make sure there are no kinks jn the pipes. If pressure is to high then just turn taps down a little.
Mar 12, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
May 22, 2009 | Washing Machines
Stoped during speen and since then no power. lights are off no conrol lights coming on. cheqed fuses etc, no imrovement. it is hot point AQUARIUS WT 540 16 months old
Hi, it sounds as if your capacitor has blown.
make sure the power has been disconected for at least 24 hours before checking this as it holds power for ages.
where the mains lead goes into the appliance it goes directly to the capacitor, if you know a good sparky he may be able to test it before you get a new one.
Mar 01, 2009 | Hotpoint Aquarius WD63 Front Load...
Wt 540 hotpoint
You need to test the pump seperatey with a independent supply to determine that the pump is working, if it is and it still stops at the rinses, then you are not getting a supply to it, so could be a board problem.
Ensure it is not on rinse hold or crease guard (same thing)
Dec 10, 2008 | Washing Machines
Mitsubishi tv wt-42311
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Washing Machines Logo
107 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
