Question about Electronics - Others
Memory upgrade question
I bought 2 gb of centon pc2-5300 laptop ram from CompUSA yesterday for my toshiba satellite A135 yesterday. Tech said it would clock down to replace the pc2-4200 ram. System worked fine for 4 hrs then crashed. Memory test says contact manufacture of ram. CompUSA is going out of business and won't replace it, Centon tech support is closed.
Is this just my Karma?
    Novelist:
  • 188 Answers
Yes that RAM should work fine even at the slower speed.
I have had terrible luck with Centon ram - I don't know why but they seem to have more failed chips than most brands.
If Compusa wont replace it see if they will refund you. Otherwise wait until Centon is open and at least you can warrantee it. See if they can swap for PC2-4200 to make sure of compatibility.
Worse case you can get Crucial (micron) RAM which almost always works at good prices from www.newegg.com or directly from www.crucial.com
Posted on Dec 21, 2007
How to replace CD?DVD IN A135-S4467
It's very easy. First turn the laptop off with the DVD bay open. You will have to unscrew the memory ram cover, and pull it.
Afterwards you take a look at the screw that's on the left of the ram's compartiment. See this picture:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/take-apart-laptop/toshiba-satellite-A135-02.jpg
If you look close to the ram compartment you will see a screw on the left side. Unscrew it and that's it. You will only have to pull the dvd rom firmly outside the laptop-you can pull it from the bay, that why I've told you to let it open.
Feb 04, 2011 | Toshiba Satelite A135-S4467 Notebook
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
Can I get a memory upgrade?
Here you go:
http://www.18004memory.com/toshiba-satellite-a135-s4427.asp
Aug 16, 2010 | Toshiba Satellite A135-S4527 Notebook
Running slow
free up some memory. be sure you free up at least 50%. how much RAM do you have? if you have 1 gb or less upgrade it. install later version of windows like 7. if you wanna buy RAM memory, buy 2 gb for 60$
Jun 28, 2010 | Toshiba Satellite A135-S4527 Notebook
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
Memory upgrade not working
check front side bus for new ram & old ram ,sometimes if both are working on differant f.s.b. then also this can be happen
Mar 15, 2009 | Toshiba Satellite A135-S4527 Notebook
Memory upgrade
check the compatibility of the ram.. also,, check the maximum upgradeable memory of your notebook..
Feb 14, 2008 | Toshiba Satellite A105-S44284 Notebook
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
Upgrading Ram on my Toshiba A135 S2386 Laptop, still under warrantly
Hi there. There are 2 locations on the border of the plastic cover, both on the same side. You need to use a small flat screwdriver or your nail, and lift the cover using those 2 spots. It will snap out of place ! If you hold the laptop upside down, the front of the laptop closest to you, the 2 places where u need to lift are on the right side. You need to lift on that side, and the plastic latches are on the left side only. Hope you see what i mean ! But basically, lift right side. Thanks ! cheebster.
Jul 09, 2007 | Toshiba Satellite A135-S2386 Notebook
Electronics - Others Logo
51 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
