Question about Kenmore Elite 45986 Front Load Washer
Fabric softener dispenser won't drain - Kenmore Elite 45986 Front Load Washer
  • 58 Answers
Just a thought, It has probably Gummed up, Take out tray if possible and clean with Hot water to disslodge it.
Use Quality wash Liquid that doesnt need conditioner. Thats what I do anyway
Posted on Oct 03, 2009
    Problem Solver:
  • 14 Answers
Byb a new one
F3 error on my whirlpool washer
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Oct 11, 2010 | Whirlpool Washing Machines
Kenmore electric range gets a f1/f3 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 10, 2010 | Kenmore Slider/Casement Air Conditioner
Error code FO3 Kenmore washer #417.44072300
Oct 14, 2009 | Kenmore Washing Machines
Error message E3 on my Kenmore Elite Dryer
Oct 12, 2009 | Kenmore Elite 45986 Front Load Washer
I have a F 03 code.
Hotpoint aquarius wf 630 error code f-03 how do i fix
Aug 14, 2009 | Washing Machines
My Sears Kenmore washinging is getting an F03 code and will not drain - HELP
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly. The fabric softener dispenser works on a siphoning principle. Make sure that the siphon hole in the dispenser is clear and not restricted or plugged. You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it. Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer. You can use the diagnostic test described below to test the fabric softener dispenser. If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining. You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer. You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum. To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump as shown in the second image below. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
Jul 29, 2009 | Kenmore Washing Machines
Error code 03 what does this mean
Jul 09, 2009 | Washing Machines
Fault code
Apr 12, 2009 | Washing Machines
Washing machine is showing F-03 on the digital display
Mar 21, 2009 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
220 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
