Question about Garden
My weed eater will not stay running.I changed fuel lines, but don't know the routing , for the lines were not there from the beginning.
2 Suggested Answers
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    How to change the fuel filter on a Weed Eater Feather Lite FX265Xtreme 25cc. The weed eater stars but won't run.
    Use a hooked piece of wire to snag the filter through the fuel tank, it should pull off the fuel line.
    Oct 12, 2011 | Husqvarna Forest & Garden 125c 17"...
    ON OF THE GAS LINE BROKEN INSIDE TANK.. IT **** AIR.. HOW DO I KNOW WHERE IT GOES..
    Try the SEARCH feature on this site. MANY posts have been made about fuel line routing for this and other models (tey are basically all the same). Search for : Weed Eater Fuel Line or Weed Eater Fuel Line Routing. It is there because I have been there and seen it.
    Aug 10, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
    Powerpro 17" McCollich weed eater
    hey harry the float inside the carb is stuck i would suggest rebuilding the carb
    Jun 27, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
    Fuel line crack dry out, in pieces
    The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Find your saw here:
    Poulan.com
    http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
    Fuel Line Replacement
    SmallEng.com
    http://www.youtube.com/watch?v=JrXpU70Hmi0
    Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
    I think the second line on the carburetor is an impulse line and connects to the crank case. HTH
    Lou
    Oct 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
    Poulan ppb 250 weed eater, only runs with choke on,
    HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
    Sep 20, 2009 | Garden
    Fuel hoses routed wrong on weed eater fuel tank
    Apr 04, 2009 | Garden
    Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
    Mar 16, 2009 | Craftsman 25cc Gas Line Trimmer
    Garden Logo
    153 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    john h
