Question about Mitsubishi WS-65809 65" Rear Projection Television
Where can I find instructions on changing lamps? I am assuming that is the problem since I have yellow or blue outlines around test and outlines of bodies.
  • kmorey1 Oct 03, 2009
    When I checked the convergence the red moved but the blue did not. Can you tell me what to order and how to change them? Thanks for the help.
    Sorry - didn't think they allowed any e-mail addresses
    Mine is kmorey1@cox.net.
    Thanks again
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If you have 3d looking picture and in the customer menu the convergence will not adjust---you have a convergence problem
This model (ws65809) uses two STK-392-570 convergence IC'S---both need to be replaced and the set adjusted----I can tell you what is needed if you want to know---I have repaired hundreds of these sets
Go into customer menu and select convergence--if either blue or red will not move in some direction---convergence problem---You can buy a pair of the chips on Ebay for about 14 dollars plus shipping and if you are able to do the repair yourself--you can save a lot of money.
I have instructions for this repair but I am not allowed to post MY email address here.
Let me know if I can help you--if you have questions or want options reply to this posting.
SD TECH
Posted on Oct 03, 2009
  • SD Tech
    SD Tech Oct 03, 2009
    Did you read about my not being able to Post my email address here? nothing prevents you giving yours........
  • SD Tech
    your info does not work----look thru all my postings here and you will find my information regarding this
I have a 4 ft 2 lamp flourescent system. I am changing the ballast. The existing wiring has blue / red / yellow / black & white wires. I have a new ballast (yes I confirmed at the store it is the...
The first thiing I suggest is checking the installation instructions (either included with the ballast or on-line) of the ballast you just purchased. Many fluorescent ballasts require that the lamps be wired in series - which I believe is what you had before. One lamp connects between the red & the yellow, the other connects between the yellow & the blue. Other fluorescent ballasts require that the lamps be wired in parallel - which may be what you have now (both lamps connect between the red & the blue). The installation instruction sheets should designate the appropriate wiring configuration.
That being said, just double-check one thing: Make sure the new ballast is rated for 2-lamps. Ballasts rated for 1-lamp will only include the red & the blue (no yellow). So I know you sad you already checked with the destributor, but double-check that one point.
May 15, 2011 | Electrical Supplies
Color problem with Toshiba
tv is on it's 'hospice' end of life routine..unless you want to gut it completely, and replace all the electronics..
Apr 19, 2008 | Televison & Video
Blue outline around images on screen and also on menu yellow offset. picture was fine. I have tried convergence and did not help
Have the convergence IC's replaced. Only one has failed but have both IC's changed as the other is not far behind..
Thx please leave comment
Oct 08, 2009 | Televison & Video
I have a viewsonic pj500 projector which has functioned perfectly for 5 years. Now the area around the image area either shows a dark blue with dark stripes and the image area has a yellow cast which seems...
LCD projector 101, your blue device is dying inside of projector. Consider purchasing a dlp based product, they do not suffer from color decay.
Really you are blessed , most lcds last about 3-4000 hours or 4 lamp changes. good luck
Apr 13, 2009 | ViewSonic PJ500 Multimedia Projector
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
Double image in bright blue with philips model 55pw9363/17f
You may have 1 of two problems.
1) Convergence Chips are failing - Using your original remote goto the "convergence" screen.
Try to adjust the red - UP - DOWN - LEFT - RIGHT
Next try to adjust the blue - UP - DOWN - LEFT - RIGHT
If you can move both colors in all directions you do not have a convergence issue.
If you can't move one or more colors in one or more directions the convergence chips are defective and need to be replaced.
If your convergence chips test out ok the most likely problem is......
2) CRT Coolant is cloudy  - The bright outline you described is one common symptom. Other symptoms include dull images, red or orange tint, halo around images.
If you goto the site www.TvRepairKits.com - and click on "Tips" - you will find more detailed instructions on how to check the convergence.
Dec 04, 2008 | Philips 55PW9363 55" Rear Projection...
2001 Philips 43P8341Blue outlines on images
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 10, 2008 | Philips 43P8341 43" Rear Projection...
BLUE AND YELLOW
If you go to the following link we have the service manual for your set for 10.99 and we offer unlimited chat support to help you diagnose and repair your set. Just click on the panisonic link. If you click on the contact us link and provide your email address we will email the manual right out to you along with instructions on how to enter into chat with us. I am one of their support Techs. Hope this helps.
http://servicemanuals.vstore.ca/
Jan 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Yellow/blue outlined image while viewing
reset the settings to factory default. the resolution and phase is off. also make sure the projector is not too close to the screen.
Nov 29, 2007 | InFocus LP 735 Multimedia Projector
Mitsubishi WS-65809 65" Rear Projection Television Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
