Question about Canon PIXMA iP4000 InkJet Photo Printer
Scanner is scanning an 8 1/2 by 11 sheet into two smaller files even though I have the setting on 8 1/2 by 11.
4 Suggested Answers
michael_grey
  • 365 Answers
SOURCE: When I scan an 8 X 11 page, it scans it into
Set your paper type and size through the control panel LCD screen.
Posted on Jun 17, 2009
MIlfordPrint
  • 90 Answers
SOURCE: I can't scan an 8-1/2 x 11 sheet on one page-it
Hi there. It sounds like you are not correctly setting up your page for scanning. Are you just putting the page in and hitting scan or are you going through the scan "wizard?" You need to let the scanner know what you are printing (color pic, black and white pic, text doc, etc.) and how big it is. Let me know what happens.
Posted on Aug 03, 2009
SOURCE: don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Posted on Jan 23, 2011
Lexmark pro205 trying to set scanner for 150 dpi scans to big need smaller
If you're concerned about the file size, uninstall the Lexmark driver and download an updated driver online at www.lexmark.com. That should reduce the file size of the scanned documents.
May 16, 2012 | Lexmark Prospect Pro205 Wireless...
I'm trying to scan an A4 size sheet(document). I was getting the same size of the scanned sheet, but now its shrinked its size so that I can not getting the same size as in the sheet. Please help me...
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Aug 24, 2011 | HP ScanJet 2400 Flatbed Scanner
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
When I save a scanned document you increase the file size. Please. Thanks.
Document size can be set before you scan.
Your scanner software should give you options for type of document and resolution settings. If your documents are to large, set resolution lower.
Example, Black and white or greyscale scans are much smaller in size than color documents.
Saving files as jpg will compress the file for storage.
If you have an image editing program you can decrease the size of the file after the scan.
Dec 09, 2009 | Kodak Office Equipment & Supplies
Scanning files to large
It's the resolution you are using to scan. Try a lower setting. for documents, 150-200 dpi is fine. That will produce smaller files.
Aug 25, 2009 | Dell 922 All-In-One InkJet Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
Scanning mode, unrequested crop
There many program to reshape or crop /adobe photo shop/corel draw.it make drawing became smaller in size to fit scanner.
Sep 02, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA iP4000 InkJet Photo Printer Logo
20 people viewed this question
old marine
old marine
