Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
How far will a 1/2 horse shollow well pump pull water from a sorce? Not vertical, but horizonal?
  • 832 Answers
To be very effective 60 meters horizontal and 20 meters
vertical distance from a water source free from pipeline leaks.
Posted on Oct 03, 2009
How do i replace a lateral pivot
remove the multiport remove sand with a shopvac then take the vertical pipe up the horizonals and the vertical pipe then can be checked for damage
Jun 15, 2014 | Hayward Pro Series 18" Above Ground Pool...
I have a 16 horse v twin on my power washer,every time i pull the trigger the engine slow down
When you pull the trigger the motor comes under load as the pump starts to work at full pressure. Check for throttle control and setting for engine speed under load.
Apr 20, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Have 3/4 hourse shollow well pump. When I turn more than one thing on such as outside hose and inside faucet, trips the pressure switch on pump, and has to be reset.
The switch you have on the pump with a reset lever is a low water pressure switch that will trip when a load is on the pump like a leak or no water in well and switch will trip to save life of pump. One way to get around this is to install a regular pressure switch and it shouldn't trip out.
Advantage of a low water switch is to save the pump and it constantly triping can be frustrating and I have changed some to put a regular switch in to avoid having to go offen to reset switch.
Aug 02, 2011 | Wayne Water Systems Plumbing
I have a Century 1081 115v, 2 speed pump for my waterfeature. The motor runs fine in low and high spped, the pump impeller is spinning but it dies not pump water.It is a 3/4 horse. The waterfall reservoir...
I don't know the answer to this ... your pool service company can advise you. To my way of thinking, you are asking a lot of a 3/4 horse. I have a 1 1/2 horse lifting water in a two inch pipe about 4 feet to my water feature with no reservoir.
Since you have a two inch pipe, why not run a bigger motor? I have two HP on all my filtered lines which are 2" suction and 2" discharge.
Are you absolutely sure you have suction? ... and no air leaks on the suction side?
Apr 24, 2011 | Century New Magnetek Pool Spa Pump Motor...
No water pressure coming out while ingine is running. hoses/ attachments not clog. Pulled and opened pump, didn't see anything broken although noticed pump was filled with oil/lubricant but about 1/4"...
Sounds like the pistons in the pump are frozen up or there has been some damage to the pump, like water left in the pump that froze. It could have cracked a part of the pump. Not knowing what pump is on the unit, whether it is horizontal or vertical pump. If it is a vertical pump, most require a pump replacement. If it is a horizontal pump you may be able to find a rebuild kit for it. You can use a 30w oil in the pump and it does not need to be full, about 1/4 " form the top is fine.
Dec 30, 2009 | Karcher Garden
Shollow well pump does not maitain pump presure water trickels after a few seconds.
The foot valve faulty at bottom of the water line at the bottom of the well most likely has gone bad. Or a leak anywhere in the water system from the pump to the well.
Jun 23, 2009 | Plumbing
New 1/2 hp jet pump with tank not working
Your hose size is to small. Use a 2in black plastic line out to the lake. Inspect your foot valve, and
take your pump apart to see if you may have a pebble stuck in it, and remove the inner workings
and clean. Contaminates build up inside and need to be flushed out. Remember to replace the
gasket. Tighten all your hose clamps. Once your ready to start, spray shaving cream on your
fittings to see if your sucking air. I've been through it all and my pump works fine.
Chuck
May 03, 2009 | Plumbing
Horizonal and vertical off.
My picture is too big for my screen also, I have a 27 inch screen and I can't see the scrolling tickers on the bottom and the baseball score readout on the top. When I turn the tv on, the heads are huge on the top and that finally comes into proportion, but it goes too far. I can't find a horozontal or vertical control in the manual or on the tv menu. What can I do?
Apr 29, 2009 | Curtis-Mathis CM27101S TV
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
215 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
