Question about Linksys WRT160N Wireless Router
I have been trying to get conected to my network with my ITOUCH but it wont accept my password how do I change the password for logging on with my ITOUCH
  • 404 Answers
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 04, 2009
Cant accept my log in to my facebook account
Make sure your ID and Password are correct and match. Normally your e-mail address is used to log in. If you fail click on the "forgot password" button and follow
Aug 11, 2011 | Facebook Social Network
Itouch problem with internet conection
Go to Settings and then click on Wi-Fi select your network and then put in your password and you will be able to connect. Hope this helps.
Dec 25, 2009 | Apple iPod touch
Can not connect to the internet with my new itouch. Have tried all the resets. My password (which is correct) does not seem to work. Says unable to join network. The network is working fine with 2 other...
try unsecuring your network for a test run and see if your ipod can connect if it can theres a problem in the security between the ipod and the router if not then its in the ipod try conecting it to the pc and updating the software its running
Sep 20, 2009 | Apple iPod touch
Wont go into facebook after log in
it lets me log on with password, accepts it then will not go into facebook. have tried everyway i no how with same results.
Aug 31, 2009 | Facebook Social Network
My itouch won't connect to my wireless network
This happened to me as well. Turned out the iPod touch doesn't support WEP encryption properly, and sometimes can't log onto those networks.
If your network is WEP-encrypted, try changing it to WPA.
Aug 02, 2009 | Apple iPod touch
Itouch wont connnect to the internet.
maybe you need to reconfig your wireless router. and try to clear history,cookies, and cache from safari.
Jul 23, 2009 | Apple iPod touch
Zyxel router connection problem
i have zyxel router for last six months it worked fine for few months but after that it start droping conection regularly after every 2 to 3 minutes .then i send it in warranty but they send it without repair as they told me that for voice you need some nice router like netgear ot belkin...lol..
this is my experience with zyxel ..before i use netgear and belkin i never have any problem with them...
Jan 09, 2009 | Zyxel (91-004-361002) Wireless Router
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Jan 04, 2009 | Westell Wirespeed VersaLink...
Apple ipod itouch connection to wireless internet
don't let the iTouch connect to the wi-fi network it detected automatically - try setting up a new wi-fi network from scratch.
the setup screens will ask for network name (the SSID) the security protocol (probably WPA-PSK if you are having all this trouble) and the password (pre shared key)
should be all you need - good luck
Lardman
Aug 05, 2008 | Apple iPod touch
Wifi connection & itouch
I finally discovered the problem. I have a Linksys wireless
router, so when I tried to log on with my iTouch, I got the
message "Unable to join network "my network name" when
I typed in my password. One day, after many trys, I tried
typing in the network security key for my router, and Voila,
it worked. For some unknown reason (to me), the iTouch
recognizes the the network security key as the password.
Mar 31, 2008 | Apple iPod touch
Linksys WRT160N Wireless Router  Logo
94 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
