Question about GE JVM1410 Microwave Oven
I believe the magnetron just went out
I think the magnetron just went out on my microwave and I was wondering if it is worth purchasing a new one(no service charge) just parts and labor, or go through GE and have to pay for a service call 70$ in addition to labor??? Is it going to be a wash?
    Sergeant:
    Champion:
  • 240 Answers
Make a few phone calls and get the actual costs-then decide. You cant normally fix microwave ovens yourself though. Generally when the magnetron goes its time to buy a new micro unless its under warranty.
Posted on Oct 03, 2009
I was heating my tea and I heard a loud pop and the unit turned off...I thought I had blown a fuse and went out and checked fuse box..flipped all fuses and microwave still not turning on at all...micorwave...
The description you provide indicates the magnetron has failed, "heats food" and blown the main fuse in the microwave oven, since the unit is 10 years old it is much cheaper to replace with a new one rather than have it repaired.
May 15, 2011 | Amana Radarange Microwave Oven
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Jul 17, 2010 | Amana LD10 1000 Watts Microwave Oven
Microwave won't turn on
When you say that the microwave won't turn on, can I assume that you mean that the food does not heat up! If that is the case, the problem lies with the magnetron circuit. This circuit consists of the transformer, rectifier and the magnetron, the part that generates the microwaves to heat the food. If it is the magenetron, then it probally not worth fixing since the cost to purchase the magnetron is almost as much as a new oven. To diagnose if it is the magnetron that has failed, when you turn on the oven, do you hear a louder that normal hum or buzzing sound? If that is the case, then it means that the magnetron is shorted and needs to be replaced.
Hope this helps.
Jun 18, 2010 | Sharp R-1502 Microwave Oven
Oven won't heat food
Bad Magnetron. Unfortunately, and especially on high power microwaves, magnetrons do die. They'll probably run you between 100 and 300 dollars to replace. If you believe that your microwave is within warranty(not likely), contact the manufacturer for repairs. Otherwise, it may just be cheaper to purchase a new microwave.
Sorry that this answer doesn't produce a happy result, but it's an unfortunate fault of microwaves as a whole.
Apr 23, 2010 | Maytag MMV5186A Microwave Oven
I warmed up a cup of coffee in our microwave then
This usually means that the magnetron circuit has failed. The magnetron is the part that generates the microwaves to heat the food. Typically the problem is the magnetron itself that has died. The cost of replacement comes close if not more than a new microwave oven. Unless the oven is still under warranty, it not worth fixing.
Feb 14, 2010 | Sharp Microwave Ovens
I have a model #565.68421 purchased in April 1998. Clock and timer work but it stopped working otherwise. Is it worth exploring repair? Any suggestions for trouble shooting?
At the price of a new microwave, it is not really worth exploring any further. If the magnetron gave out, it's cost alone without labor would be excessive.
Dec 28, 2009 | Kenmore Microwave Ovens
When you select cooking cycle pressing the start botton the clock will count down whatever is in the oven does not heat up. HELP !!! THANKS
Sounds as though your Magnetron is not working.
This is the heating part of the microwave and in most cases is not easily accessible.
You may unplug the microwave and if you have a exhaust type microwave then there is screws either on top or in the front that allow you to remove this section, and once removed you can remove the screw on top of the controller, which gives you access to the fuse and fan and electric components inside.
Make sure noting is melted and smell to make sure nothing smells burnt.
In most cases, if it is the Magnetron then between labor and parts you almost better off to purchase a new microwave.
Good Luck!
Nov 16, 2009 | Microwave Ovens
Will not heat food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Jun 15, 2009 | GE JVM1650 1000 Watts Microwave Oven
Give out a buzzing noise with a burning burning smell. Is it worth fixing or should we get a compatible replacement since this model is no longer available. Thanks
This is a common symptom of a failed magnetron, or defective wave guide assembly. The price of a new magnetron is about $120. The waveguide (if defective) cannot be purchased without buying a new unit. Your choice. Do you think its worth repairing? You can purchase a new magnetron, but if the waveguide is damaged, the unit will still exhibit the same symptoms you are experiencing. Its not often that I give advice NOT to fix something, but in your case, it may not be the best choice.
May 03, 2009 | GE JE1640 Microwave Oven
Not heating properly
I have a GE over the range space saver microwave that was only 18 mos. old when it stopped heating. GE replaced the magnetron for us at no charge but since we did not have a service contract - they charged us $200 to install it. It only cost $375 new installed. Your choice.
Nov 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1410 Microwave Oven Logo
101 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
