Question about Hotpoint Aquarius WF000 Front Load Washer
Hi,How do you get to the bearings on the back of the drum.Its a hotpoint wf000.Thanks
    Problem Solver:
  • 14 Answers
If you tell them their not really round that should upset them
Posted on Oct 03, 2009
2 Suggested Answers
SOURCE: noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Posted on Nov 08, 2008
I have a Hotpoint Aquarius WF541 that has started making ean extremely loud noise when on spin. The machine remains still, but sounds like a jet engine. The drum makes an awful noise when I turn it...
maybe it the pulley tensioner came lose.....open up the back of the machine and check if the belt is tight...if not get the spanner out retention the pulley arm and retighten.
Jul 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a aquarius hotpoint 340, bearing gone
You have to split the drum to replace the bearings
The reason the bearings have gone is that water has leaked into them and the soap content has destroyed the grease
There is a carbon seal on the spider assy which attaches to the back of the drum , this normally cracks so the spider or seal has to be replaced
Feb 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
May 27, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint motor problem after renewing drum bearings!
Hi dave, Its nothing you have done! It will need the carbon brushes changed in the motor as they have got low. The arcing is caused by the brushes not touching the com properly. Just change them and it will be all good.....
Mar 07, 2009 | Hotpoint Aquarius WF000 Front Load Washer
We need Bearing
Sadly, some of these machines were manufactured with a completely sealed drum making bearing replacement impossible. If the shop is selling you a complete drum, I would say you have such a machine otherwise they would sell you a bearing kit. Lots getting caught with this one :(
Feb 25, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wf000 aquarius
if the drum moves slightly up and down then your bearings are in need of replacing u can also check this by going to the back and taking the little cover of in the centre of the back check around the centre of the spider wheel if there is a mucky water mark then they do need replacing this will cost from £90-£150 to replace love
Nov 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Noisey washing machine
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
How to replace a Hotpoint Aquarius+ WF740 drum bearing?
I had the same problem and it turned out to be the ballast securing bolts had sheared off and the back of the drum had to be replaced
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
89 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
