Question about Moulinex DG6 Food Processor
Replacement serrated drive?
I was chopping ginger and ginger stuck in the blades of chopper and the grey rubber(serrated drive) got effected badly.i have a spare part but i dont know how to replace it.please help
  • grate Mar 11, 2008
    I grating potatoes when the processor seemed to jam. The square opening on the peg that held the rotating blade lost two of its gromets and forced the blade down on the "post". I could not get the blade off the "post". I sent the post with blade stuck on it to Moulinex Products, Inc. 2820 Crusader Circle Virginia Beach, VA. 23456. The box came back today "Undeliveable". Where can I send this?????
I need replacement chopping blade. Help please
You should be able to do a search for your particular manufacturer and model food processor using one of the search engines. For example if you are looking for a Cuisinart model CH-4-DC chopper blade enter the search terms Cuisinart Model CH-4-DC chopper blade replacement in your search engine. Amazon is usually a pretty good place to start.
Mar 29, 2015 | Food Processors
Kitchen aid food processors 's chopping blade gets stuck . Very hard to take it out
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Aug 23, 2013 | Magimix 5100 Cuisine Systeme Food...
Ultimate chopper/blender is leaking. Where can I get a replacement
probably its the rubber that hold the blade cover to the mug is damage..if you cannot get a rubber then you need to buy new blender.good luck.
Sep 23, 2011 | Ultimate Chopper Food Processor
Breville foodprocessor Wizz Professional FP16B Is a replacement metal s shaped chopping blade available Paraparaumu Beach New Zealand
is there anyone know where to find a blade chopper for breville wizz profesional fp16b model.
May 17, 2011 | Food Processors
Chopping blade is lost. I do not have name of machine. It is a counter top small food chopper with wall-mounted blender attachment and whisk also.
I realise by looking more closely that you are an American site ($) so I am going to try to source my part nearer to home. Thank you. G
Oct 28, 2009 | Braun Food Processors
I had just finished cheese and couldn't get the
If still interested in a replacement for the Ultimate Chopper - there is a website call TV Time Direct - website: http://www.tvtimedirect.com.
Their phone # is 800.238.7119. On their website, use the Quick Find option (upper right corner) - type in Ultimate Chopper and it will list the replacement listing for this item.
Oct 04, 2009 | Ultimate Chopper Food Processor
Replace my chopper blade
Hi there, it's hard to find a supplier if there is one in the uk,as most TV Products are american but made in china, however there are two areas where you can try and find replacement parts, one is to the retialor direct here http://www.ultimatechopper.com/request-custserv.html which i believe is a good option, or there is a site that sells parts but i did find it a little confusing, it this one http://www.chinasuppliers.globalsources.com/
The first option at least gives you contact details and a support area and you will get help from them 100%
Best Of Luck
May 28, 2009 | Ultimate Chopper Food Processor
Replacement parts for the "Power Chopper blender"
same problem too!
I have my chopping blade broke, I need the new one.
please email me (mamakoi_saja_yahoo.com) where I can order one.
Jan 27, 2009 | As Seen On TV Power Chopper PC4 Food...
Ultimate chopper replacement parts
Yes, ultimate chopper parts are available, and the can be found easily on amazon, click here: Amazon com Ultimate chopper replacement parts, and take a look. Wish you best of luck. Cheers
Aug 02, 2008 | Ultimate Chopper Food Processor
Moulinex DG6 Food Processor Logo
94 people viewed this question
Top Moulinex Food Processors Experts
Colin Stickland
Colin Stickland
Marvin
Marvin
Ross Keen
Are you a Moulinex Food Processor Expert? Answer questions, earn points and help others
