Zenith R57W46 57 in. Rear Projection Television
Problem for Zenith R57W46 57 in. Rear Projection Television
My screen is green and red, kinda like a 3d
By peewee73110 on Oct 03, 2009
My screen is green and red, kinda like a 3d showing
Solution #1
posted on Oct 03, 2009
Somewhat Helpful)
Chu3505
Rank: Guru  Televisions & Videos  Expert
Rating: 85%, 415 votes
U must know how to solder,before can replace parts,ICs delicate soldering work.Tries buy a whole board, if u don't,cheaper less heaches later.Tries these websites for convergence kit,replace what parts in that kit.Tries Tv repair world.com,Ebay.com.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
djeletronics
Rating: 91%, 64 votes
The problem with the unit is convergence.Remove convergence output board then replace IC2701 and IC2702 both of them are STK-392-120,After replacing ics you have to go into the menu of unit to adjust convergence.Align the red ontop the green then blue ontop the green.
Was this helpful?
Yes
No
Solution #3
posted on Nov 05, 2009
Not Rated)
louis66
Rating: 90%, 16 votes
You can fix it yourself for less than 100.00
This is a very common failure on projection sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here on Fixya
Solution Link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Was this helpful?
Yes
No
Popular Solutions for Zenith R57W46 57 in. Rear
Questions and Unsolved Problems for Zenith R57W46 57 in. Rear
Do you recommend Zenith R57W46 57 in. Rear Projection Television?
Answer
Answer
how do i manulay configure tv? i want to try this before buy chips! zenith projection rw 52
Answer
i have a r57w46, im having pict prob. the sound is fine but the pict is jumpy. what would cause... (More)
Answer
my zenith hdtv converter dolby digital sound's picture is blurry
Answer
The picture is bigger than the actual screen - how can I adjust down?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zenith R57W46 57 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
