Question about Refrigerators
My son turned our refrigerator up to setting 5. When i discovered it, i turned it down to setting 3. For the past three weeks, my refrigerator has been sopping wet inside. What do I do?
    President:
  • Refrigerators Master
  • 1,922 Answers
Pull the plug put your food in ice chests or another fridge for the time let the unit sit shut off for a day or so with a fan on it to dry it out good then reset the temp setting down and start it and try it again
Posted on Oct 04, 2009
    Sergeant:
    Champion:
  • 323 Answers
Dry up any water inside the unit and then unplug for about 3 seconds and plug back in, this will reset the unit into a normal cooling cycle
Posted on Oct 03, 2009
For the past couple of weeks, the freezer will loose its cool enough to thaw or partially thaw what is in it, but two or three hours later it will be frozen again. Keeps going back and forth. Ideas?
possible problem thermostat or freezer setting to close to one setting
reset to a bigger number as the numbers work opposite to the fridge settings ( 1 is close to 0 degrees and 20 is -20 degrees ) where as in a fridge 1 is close to 0 degrees and 5 is + 5 degrees above 0
Sep 10, 2016 | Refrigerators
Refrigerator seem to not cool to the proper
your problem is in hte freezer area open the panel in your freezer you might need a new heat element or a new thermostat unit... not so bad to do or check...
arik from 911.servicetoday.com
Nov 06, 2009 | Kenmore 53092 / 53094 Side by Side...
Iphone shuts off by itself
It is the phone power saving mode. You should set it to maximum time if you don't want your phone to shutdown rigthway when idle. Go to phone settings do it.
Nov 03, 2009 | Apple iPhone 3G
Drop in oil pressure
The oil sending unit could be bad, or the pressure relief valve in the oil pump is malfunctioning.
Jan 28, 2009 | 2003 Chevrolet Silverado 1500
Error message
Resetting the EEPROM
1. Press and release the On button to turn the printer off.
2. Press and hold down the Stop, B&W, and the Color buttons.
3. Then press and hold the On button until the LCD screen flashes three times
4. Release all the buttons. The screen displays Init. EEPROM
5. Press and release the Color button again.
6. Press and release the On button to turn the printer off.
7. Press and release the On to turn the printer on.
Nov 26, 2008 | Epson Stylus RX500 All-In-One InkJet...
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
Ge Refrigerator stopped working
Deet, Unplug the refrigerator and the 3 pins on the compressor. Remember where the three compressor wires  go when you put them back on. Test all three pins 2 at a time with an ohm meter. You should get readings all the way around. Then test 1 pin at a time touching the other probe to the copper on the outside the compressor. Tell me what you come up with, Thanks, JT
Oct 23, 2007 | Refrigerators
Refrigerators Logo
605 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
