Question about Christie Vivid Green Multimedia Projector
When hooking up r,g,b via component or vga input only the green channel displays.
  • 2,237 Answers
Reset the settings to factory default, then make sure if you are using component that the input selected is component and not vga. is the source rgb-yb?
Posted on Jan 06, 2010
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
I have an e470vl vizio hdtv. i was plugging another component into the wall when the whole outlet sparked (biggest i have ever seen/felt). the tv and dvd player were connected to a power strip to that...
first of all just switch off everything then switch off the mains, open the mains socket as there might have been a loose connection to the terminals which you`ve got to tighten. also confifrm that the earthing is well connected before you switch on .
swtch on the mains then switch on your devices one by one, also confirm that the VGA cable is well connected to the display unit
Sep 17, 2011 | Televison & Video
I have a vga component cable adapter to hook my RCA scenium to my PC.Show me display of where the red, blue and green plugs of said adapter go.
it has to be HDTV ready, if it is it will be color coded on the inputs at the back of the tv. otherwise refer to this link to see what the back of a tv that uses the component cables looks like. http://www.soundandvisionmag.com/files/_images/121200315215.jpg
Jun 12, 2011 | Televison & Video
How to hook up xbox 360 to jvc dlp thru hdmi ports
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
Hope that helps.
Aug 27, 2009 | JVC Televison & Video
Hi there I don'tseem to be getting any component video output. I am inputting virgin via optical input video 1, I get the sound and the box even displays virgin but no visual output?
Optical is for "audio only" you need to send Video from whatever source you are hooking up, ie. TV,DVD,DSS,etc. Use what the source has, if it's got Component Video out, use that, Don't use HDMI! still too many firmware issues! Make sure when you hook it up to the receiver that you hook it up to the same input as your audio, just on the video side. It will say DVD or DSS or CBL next to the green,blue,and red inputs. Hope this helps
Jun 21, 2009 | Sony STR-DG500 System
Hooking up a dvd
You want to hook up the cables to any of the VGA input sets. Red= right audio channel, White= left audio channel, Yellow= Video. Don't plug them into the sets that have Red, , Green, and blue inputs. Just the set with red, white and yellow. Now you won't get HD from this since it's not bluray or HD-DVD. Just be sure you select the corresponding input on the TV when you want to use the DVD player. For example, select input 1 from the on screen display if that's the one you plugged it into.
Nov 07, 2008 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Feb 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Christie Vivid Green Multimedia Projector Logo
180 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
