Both togggle switches are broken
Have Duracraft CZ 600 oil filled fanned portable heater and has two switch on end for different watt settings. both switch made out of cheap plastic and have been broken
    President:
  • 1,714 Answers
Go to the hardware store and match them up, they have toggle switch. Get the heavy duty 20 amp switch.
Posted on Oct 03, 2009
Ew6507l - nowhere near warm enough
only made for 400 to 600 sq feet try Eden pure heater 1500 watts than cover 1000 sq feet the oil fill heater might have a switch 600 to 1500 watt there r usually a high and low to them good luck
Dec 11, 2013 | DeLonghi 6507L Oil Filled Radiator Heater
The electric cord on our Duracraft heater model CZ-600 was very hot to the touch (closest to the plug) -- it burned so hot we could not touch it for more than a second. The heat was at maximum and we...
Look carefully at the plug's connectors to see if thewre is any scorching or otherwise burnt metal...electrical connectors tend to get hot due to the plug being loose(this causes more resistance and thus more heating). As a safe bet...the parts aren't expensive...I would replace both the power cord on the heater AND the outlet recepticle
Jan 17, 2011 | Heating & Cooling
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
Owner left a Duracraft air heater in home, model CZ 600. I am not familiar with it, and need instructions on how to use it. Does it require water, or can I just plug it in?
Just plug it in. Water is not what is inside of unit, Oil is inside. Put the dial at the amount of heat that you are wanting to come out. Very simple poroduct to use. I have owned my unit for over 10 years now.
Sep 06, 2010 | Heating & Cooling
The heater does not work when switched on I have tested the cable up to the internal connection block and checked conntinuity through the thermoststat, all seem ok.Can you help
Someone stated this problem was a resistor located in the neutral side of power cord. That is where the problem is. However, it is actually a thermalink fuse rated at 10 amps. The heater pulls more than 12 amps. I wonder how many of these heaters have ended up in a landfill because of this manufacturing flaw!
Dec 21, 2009 | Lakewood Oil-Filled Electric Radiator...
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
Settings on my CZ 1500
To switch between C and F, hold DOWN and ENTER for three seconds.
( I sell these. )
Mar 11, 2009 | Comfort Zone NEW 09 Electric Portable...
Rocker switch for 600 watts broken----
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Dec 01, 2007 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
478 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
