I have a problem in the vertical deflection circuit on my rca tv model#p61960 chassis#ptk195y06t can you tell me where i can find a replacment board
  • faunsman Oct 03, 2009
    do you know which board the vertical deflection circuit is on and where to get a replacment
  • SD Tech
    SD Tech May 11, 2010
    IF YOU do not get a answer in the live chat reply to this post here and I will assist you.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The deflection board is part of the Main board and is not available---you do have an option---contact PTS Electronics--get a quote from them----they repair/rebuild all kinds of circuit boards---This set was made around 2002 and it is not unusual that boards are not available for it any more---someone in the chat should have known this and told you.
Let me know if you have questions or need any help.
SD TECH
Posted on Oct 03, 2009
Sound but no picture
thats a vertical deflection issue replacing the deflection board should solve the issue you can get the replacement deflection board from www.tvrepairworld.com listed under the RCA circuit boards
Apr 01, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tip
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W..,...
RCA, CRT Projection TV, ITC222 chassis Faults - models D52W.., D40W.., D56W.., D61W..
· Symptom: No Convergence, Picture is bowed and distorted, colors don’t align.
The Fuse for the convergence power supply has blown
You'll also notice that the convergence settings have disappeared from the on screen menu. The fuse likely blew because of a fault on the convergence board. If you've never done soldering or dismantled a TV before this is probably not the best place to start. The back cover needs to be removed and the fuse (see picture) identified, the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over and the fuse checked/replaced. You need a soldering iron and solder ****** or solder wick and a multi-meter to check the fuse. If you want to tackle it yourself see attached image for reference or get a quote from a repair shop (approx $200-$300 Total) the convergence board may also need repair.
  • Symptom: Dead Set - TV Tries to Start or intermittent dead.
The set could be in shut down mode due to a fault detected in the power supply, vertical or horizontal deflection circuits.
The common problems with this chassis that will cause a dead set or intermittent dead set symptom are, bad power supply capacitors, bad flyback, bad HV cap in horizontal output circuit and cold solders (on opposite side of board) especially under the flyback area. To gain access to replace any of these parts the back cover needs to be removed and the deflection/power supply board needs to be unplugged (label or mark all connectors beforehand) and flipped over.
These are only the most common problems and it could be any number of other faults.
If you have electronic (TV) repair experience check the items mentioned (see picture), otherwise it's best to seek a qualified RCA tech for an estimate/service call.
· Symptom: Erratic operation of set – turns off by self, the volume or channel changes by self or on screen menu appears intermittently.
Switches on the front panel assembly (FPA) problem.
What happens with this model is the FPA switches (one or more) start to conduct just as if someone was pressing the buttons. This in effect locks up the system control or causes it to initiate erratic commands.
The way to determine if the FPA is bad is to remove it by unplugging from set. This requires front panel disassembly.
Note: The remote will still work with the FPA removed so the set can be tested.
Hope this helped, johnnydiode, Fixya.
on Dec 08, 2009 | Televison & Video
Why does my screen go black
The set is shutting down the CRts for protection which is almost always a vertical deflection failure with that chassis if the audio still remains working when the pic drops out. Replacing the deflection board should solve the issue. You can get the ITC222A deflection board PSB260 from www.tvrepairworld.com
Mar 24, 2012 | RCA R56WH76 Projection Television
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
When plugged in, it makes a chirping sound.
hello it sound like 1 of the capacitors may blown or swelled up. with the power of you need to do a visual check of the board inside check for any burn't part i'e resistor capacitors transitors diodes any more info you need get back to me
regards
shaun
Mar 13, 2010 | RCA P61960 61" Rear Projection Television
Hello i have an rca tv the pic is bowed and the letters are double i think i need a convergence kitmodel #p61960 chassis#ptk195yo6t
STK730-010 regulator it will be on board up over chassis snaller board
Call Mats Electronics fpr Part 1-800-628-1118
Dec 29, 2009 | RCA Televison & Video
My rca truflat comes on for about 3 seconds with picture only through the middle a small line and I do have sound and then shuts itself off. This has happened before once and I pushed a bunch of buttons on...
Hello Cera if the line is right in the middle of the screen going form left to right than the problem that your tv set is having is coming from the vertical deflection circuit with either a bad component in that circuit or bad soldering on the pc board itself, to tell if it is bad soldering on the pc board it self in that circuit tap the tv set on the side if the picture comes up then you have bad soldering on the vertical deflection circuit if not than there is a bad component in that circuit which is giving you this problem and more than likely the component would have to be replaced, like the vertical deflection IC are known for this, what i would suggest is call a near by tv repair shop and get a repair quote on your tv set if it is more than 300 dollars than i would recommend for you to get yourself a new tv set thank you hope this helps.
Aug 27, 2009 | RCA HD52W58 52" TV
I would like to buy a rca 61 P61960
Hi jkclay841 i live new york and have a RCA REAR PROJECTION TV 61" MODEL # P61960 CHASSIS NUMBER PTK195Y06T
IT POWERS ON BUT IT'S OUT OF ALIGNMENT ON ALL COLORS AND MISSING THE CLOTH THAT COVERS THE SPEAKERS HAVE THE REMOTE SCREEN IS IN GREAT CONDITION ALSO HAVE SOME NEW CRT COOLANT RUBER SEALS ,AND THREE NEW LENCES THAT I WAS GOIN TO REPLACE BUT CHANGED MY MIND PLUS NO TIME.
HERE IS MY NUMBER 347- 847 -3348 IM JOSE
Apr 03, 2009 | RCA P61960 61" Rear Projection Television
RCA P61960 projection screen. no picture, no sound. tries but shuts off.
It will depend on the Chassis number you have but it sounds like a bad Deflection module or a bad Convergence power supply module. The Convergence Power supply module is on the left looking from the back mounted above the deflection module. On newer models the picture tubes can short and put these sets into shut down mode ( Three Trys). Start by unplugging the CRT modules off the neck of the tubes one at a time. If it doesn't come on you have eliminated the tubes. There will be a Red and Black set of wires from the deflection module to the convergence power supply module. Unplug it. If it fires up then it's the convergence power supply module. If not it will probably be the deflection module. The flayback transformer is a common problem along with several bad caps towards the front of the board. Let me know if this fixes it.
Oct 02, 2008 | RCA P61960 61" Rear Projection Television
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
