Question about Whirlpool GHW9100L Front Load Washer
Tub has a wobble in it . front seems loose.
The front of the tub has a wobble in it. almost like it has come loose. can this be fixed?
    Genius:
  • Whirlpool Master
  • 1,467 Answers
Could be loose bolt @ back of pulley or Drum bearing gone which makes drum very noisy on spin expensive to fix..
Posted on Oct 03, 2009
Have a GE WSXH208HWW Spacesaver, Washing Basket is wobbling. What is the problem and can I fix it myself?
2 possible problems. On the outside of the tub front and on the top back are cement counter weights that are bolted to the tub. If they are coming loose, they would cause the tub to go off balance and wobble. If just the stainless inner tub is the one that wobbles, that suggests a bad rear drum bearing. The counter weight problem easy to fix once you get the top and back off and just need re-tightened. The back drum bearing is something even trained techs want to avoid. It requires removing the complete tub/drum assembly from the washer----then splitting the outer tub in half to replace the inner drum and bearing assembly. Cost for parts will be excessive and not worth the repair.
Apr 04, 2015 | GE Washing Machines
Reattached tub, but spin cycle doesn't work
the belt might have come off of the tub take it back apart and look underneath and see if the drive belt is loose or on the floor when the tub came loose it probably slipped the belt off before stopping.
Dec 12, 2007 | GE Profile Prodigy WPSE4200A
Is this right ?
Yes, usually the tub inside a washing machine will wobble to some degree to allow operation when loads are slightly unbalanced during the spin cycle.
Aug 21, 2014 | Washing Machines
I have a 2001 ford escort zx2 and it seems as if the front wheels wobble at speed at or under 30 mph. The faster you go the wobble disappears. Is this the wheel bearing, loose lug nuts, or u-joint?
If the wobble is very noticeable at low speed I would first suspect the tyre or tyres. Start by changing each front tyre with the spare and see if that affects the symptoms.
I am assuming that you have checked that the wheel nuts are not loose?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | 2001 Ford Escort ZX2
Maytag top load washer shakes. The plastic tub seem to be the problem. I took the front off and watched it spin. The tub seems to want to lean to one side and spin out of round moving up and down. All...
Seems with your observation that the tub is out of shape and so it might be wobbling when it runs. So the only option is to change the tub with a new one but the cost must be confirmed to decide between a new tub or a new washer.
If you can get a salvaged tub it will be economical.
Sep 26, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 70 series washer wobbles very badly.
you have to remove the front cabinet to really see inside,remove the 2 top console screwa(one on each side)you will see 3 springs(check them)also the tub sits on 3 pads(check)them,let me know what you find-mike
Feb 15, 2009 | Kenmore 24032\24036 Top Load Washer
Tub is very loose bangs and wobbles
suspect basket support broke basket will need replaceing and possible rear tub section if bearing/seal damaged overloading not usually not the cause
Nov 27, 2008 | Kenmore 43052 Front Load Washer
Loose tub on GE WJSR2080V
Reach (or look) over the tub, just under the metal top, at the four corners of the machine to see if the rubber tab dampening straps are OK. (not broken) If broken, use putty knife to push in 2 spring clips at very top of front panel (a couple inches in from the L and R side) and pull to take front panel off. Remove two 1/4 hex head screws holding top to side panels. Remove top. (looks like your model has a lid switch which can be unplugged by the back splash.)
Also check that the inner tub does not rock independently of the outer tub. If it does, pull agitator and tighten large left hand threaded nut.
Sep 13, 2008 | GE WJSR2080V
Tub loose and shakes
try the tub casting under the agitator if its a top loader,if its a front loader does the drum wobble,then you will need a new drum plus bearing and seal.
Mar 14, 2008 | Washing Machines
Whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Feb 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
542 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
