E machine: screen has slid slightly to the left
E machine: screen has slid slightly to the left and I would like to slide it back to the right
  • Steve Allison
    Steve Allison May 11, 2010
    Since the answer depends on which monitor you have, you need to include the model number of it; not all monitors have the same adjustments and some require that screen position is done from inside Windows.
  • 2,229 Answers
There should be an adjustment on the monitor itself.
One button should be a "menu" button when pushed will give you the option of adjusting the screen.
Posted on Oct 03, 2009
My problem is when I put the new brakes on my Atv I can't get the drum back on, it looks like this ring is stoping the drum from slidding back on??? Do I have to remove the round c spring??
Have u re-adjusted it to reduce it enough to slide drums back in. U could do this first, slide drums back in then re-adjust to expand linings to required width. Had this problem once, brake lining was the same size and all but a slight difference on d lining metal kept touching the drum even after lining was filed down to enable the drum slide back in. Examine the brake carefully to be sure it is the right type. Unless the wheel cylinder s bad. The right brake should give the drums no trouble sliding back in.
Sep 28, 2011 | Cars & Trucks
The machine displays "please wait Drawere Full"
we had the same problem....there is a bolt on the back side of the tray that pushes on a microswitch when you slide the tray back in; if aligned you can here the switch click. Otherwise it is just slidding by and missing....so bend the bolt slightly (ours had to go to the right as you look at the machine) and see/listen as to whether the switch is tripped. listen carefully; try just tripping it with a small probe to see if you can hear and feel the switch inside. good luck
Dec 30, 2010 | Kuppersbusch K?ppersbusch EKV 6800.0 M...
Up,right and clear button not working when opened
i have the same problem on my phone and i was unable to fix it but i could get the clear, up, and left buttons to work by sliding the screen down a tiny bit until the buttons on the screen light up (they are not lit up when the phone is slid out). you won't be able to push the top row of keys, but by sliding the phone slightly down you should be able to use the clear, up, and left keys
Jul 23, 2010 | Samsung Sway SCH-U650 Cell Phone
Drum error message how do i fix that
You need to open the front cover of the machine and remove the cartridge( drum and toner).
On the top right there is a tab that you need to slide from left to right about 20 times, then bring back to home position.
Then reinstall the drum and toner.
If you are still getting the same error message, try the same procedure as above then this time blow into the area ( where you slid the tab),
If you still have the same error, you should replace the drum.
Jun 17, 2010 | Brother MFC-7340 All-In-One Laser Printer
I need a video tutorial on how to replace the CD-ROM drive in the Fujitsu Siemens Amilo Pro V2010.
All you need to do is leaver off the power button strip with a thin screwdriver. The power button strip has a slight gap at each side this is where you insert the thin screwdriver or thin leaver.
The power button strip has two plastic locking down lugs at each side they hold it in place.
Do it from the power on button side first with the screen flat backwards or you will pop off some keys.
Getting off the power button strip is the hardest part without poping off keys or scratching the case.
Unscrew the single silver screw to release the key board this screw is located slightly to the right of center although there are four locking down tabs on the keyboard it is only held down in the second one from the right. (It’s the longest screw in the laptop)
Push the keyboard slightly forward then tilt the keyboard towards you and lay flat (you should have enough strap to do that)
If you want to remove the keyboard completely you have to lift up the left and right lug each side of the strap)
Just at the right top edge of the strap connector you will see a silver headed screw, remove it.
The CD/DVD writer is now free however at the end nearest to you it is pushed into its electrical socket which is part of the motherboard.
If you press on the silver metal bit that you removed the screw from (looks a bit like a top chopped off triangle) the writer will slid out of its electrical socket, the device will come out from the right side of the laptop.
Remember if you are replacing the writer you will have to get one with the correct electrical socket.
Replacement is the reverse of removal. Slid in the DVD writer make sure it slots into the electrical socket. Put the locking screw back in. Locate the keyboard in its forward slots and slide in the strap, lock it into its connector, by pushing down the lugs either side. Lock down the keyboard with its screw and push back into place. Push the power button plastic strip into place.
Do the operation with the battery out and the power adaptor disconnected.
Hope this is clear enough and helps.
Feb 16, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amana AFI2538AEW bottom freezer door handle is loose?
My dad's freezer handle is loose, model ABB2224DEW. Went to partselect.com and located drawing of freezer door parts. Found a link to a "do-it-yourselfer" that describes removal and replacement of the handle. Hopefully this helps.
Replacement of freezer door handle.
1. Removed freezer door handle. First I read the freezer door handle removal instructions in the Amana refrigerator user guide. Removing the handle requires inserting a plastic card at least 1.5 inches under the left end of the right side of the handle so it releases the butterfly clip latch on the freezer door. Next I pulled the right side of the handle to lift it away from the freezer door. Then still holding the handle away from the door, at the spot that is 1.5 inches from the inside of the right side of the handle, I held the plastic card vertically and slid one corner of it between the handle and the freezer door and worked the card down until it released the butterfly clip latch. Keeping the card at the same space under the handle so the latch was released, I then turned the card to the left until it was horizontal and was lifting the left end of the right door handle away from the freezer door. I then slid the handle across the card to the left until it cleared both door butterfly clip latches and it lifted off the door.
2. Installed freezer door handle. First I read the freezer door handle installation instructions in the Amana refrigerator user guide. The handle is curved on one edge and must be installed the curved side down. Correctly installed, the outside ends of the handle curve upward and the handle curve is down so it looks like a frowning mouth. Next holding the handle curved edge down, I turned it up so I could see the brackets and held it against the door. I lined up the handle brackets slightly to the left of the butterfly clips on the freezer door. Next I turned the handle with the brackets against the freezer door and slid it slightly to the right until the left side of the handle held onto the door butterfly clip by itself but was not latched. Then I lined up the right handle bracket with the right freezer door butterfly clip and carefully slid the whole handle to the right until I heard the left butterfly clip latch click. Next I slid the handle back slightly left once more and then slid it back to the right until I heard the right butterfly clip latch click.
Parts Used: HANDLE, DOOR (WHT) Level of difficulty: Difficult Time to do repair: 30 - 60 mins
Apr 02, 2009 | Amana AFI2538A Bottom Freezer French Door...
I have a lg front load washer model wm2277wh. I have a problem with the tray that holds the detergent softner and the bleach, It has gotten stuck closed and I had to pry it open and have broken the tray...
I had the same problem... I cause it. I like to remove the tray and clean it. What happened was I didn't snap the softener cap, so when I slid it back in it got stuck... Here is the solution is that's kinda what happened to you.
In the back of the washer there are four screws the hold the top of the washer down.
1. Unscrew them
2. Slide the top of the washer back then lift off
You will then see the dispenser compartment.
If you look carefully you'll see it has snaps on the right side.
3. Carefully unsnap the lid...DO NOT TRY TO REMOVE!! Just unsnap.
**Don't be a Fred Flintstone!
4. SLIGHTLY! lift the right side... again, SLIGHTLY! Again, DON'T TRY TO REMOVE IT! You should then be able to slide the drawer out...
And if you did what I did to cause the problem in the first place all you will need to do is make sure the Bleach/Softener (blue covers) snaps back in place.
Good Luck!!
By the way, I fixed mine last night!! Saving me a repair bill for an easy solve!
Mar 19, 2009 | LG WM2277H Front Load Washer
Singer touch and sew 648
Thread the machine as if you were going to sew. When you thread the needle, pull the thread off to the left and wrap it around the thumb screw on the left and just above the needle. Wrap it only 2 or 3 times and hold the end of the thread. With bobbin in place and the face plate slid open, push the thumb lever on the left under the face plate to the left. Begin to 'sew'. As you do, the bobbin will wind and the thread you are holding will detach. Once the bobbin is full to the outside line, slide the face plate the closed position. As it closes, it will release the thumb lever. Put the needle in the slightly lowered position and slide something blunt under the pressure foot pulling thread from both the bobbin and the needle; cut the thread when you've pulled it out sufficiently.
Jan 19, 2009 | Sewing Machines
Flood switch
I had the same problem and I fixed mine. It wasn't hard at all. First, make sure power is off either unplug or shut off breaker. Next, open the lower drawer and on the sides toward the bottom you will see a circular recessed pin with a flat slot. Without forcing, wiggle the door down. When you get it off you have to remove the wire harness, just unplug it. Now, on the sides at the bottom, you will see where the drawer fits on the slid rail. Push the plastic button slightly to release the lock for the slid rail to the drawer and push the slid rail all the way back as to release the drawer fronm the rail. Be carefull when you release one side as to hold it up still while removing the other one. Now, flip the drawer on its side and try to get it as far out of the way as possible to the right of the unit. You will now notice a plastic cover at the back left of the unit. This is where the flood swith is. Remove this cover by sliding to the right. The will be water under the circuit board you see. Soak up as much as possible and you can use a hair dryer to get the tough spots. Now try to find the resson for the water. I had a mouse living under mine. Look for a break in one of the hoses. After all dried up turn power back in before reinstalling lower drawer. If dried properly, the dishwasher should stop beep beep beeping. Now turn water back on and run upper drawer. Inspect hoses again. 50/50 chance. If now water, reinstall lower by replacing plastic cover, place drawer on rails and slide all the way back. It should click back in if on rails correctly. Now install the door face, line up tabs into drawer, and slide up. Align holes for recessed circular pins and just push them in. Test lower. Thats all I got, Hope it helps.
Oct 03, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
HCT 8525 PDA
first, you'll have to open the 4 screws at the back,
then open it from the sides with an opener, until the back cover is removed,
then you'll remove the mother board,
then unplug the lcd-cable,
then remove the 4 screws under the mother board, which are holding the upper sliding part,
then remove the screws of the sliding part,
then again, use the opener to open it from the sides,
you'll reach the lcd.
that's it :)
mik
lolit_90@hotmail.com
Sep 07, 2007 | Pioneer NS-DV88 System
Computers & Internet Logo
David Payne
David Payne
