Question about Samsung CLP 300 Laser Printer
Colour fades on half the page especially blue turns to yellow. Using Samsung clp 300
mitpatterson
  • 74 Answers
SOURCE: CLP-300
The only way to reset it it to buy oem cartridges because it only lets you use the starter tanks once, after that they must have chips
Posted on Feb 24, 2008
  • 12 Answers
SOURCE: Samsung CLP-300 Laser Printer partially faded prints and noise from the drum
The manual says if you are getting this clicking noise that the imager is loose and to take it out and reinsert it. This is the device that all the toner cartridges are inserted in. It just Pops out so it is easy to remove and reinsert. What happens is it gets loose in shipping sometimes and just needs to be reseated.
Posted on Jun 02, 2008
  • 670 Answers
SOURCE: Pring quality on Samsung CLP-300 colour laser
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I don't have 20000 images it is about 7000 and I have a document to show you if you are handy.
Posted on Feb 14, 2009
SOURCE: smasung clp 300 will not print in blk
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Posted on Mar 07, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
I have a Samsung CLP-310 and I've mislaid the units manual. On the top of the unit down on the bottom right hand corner there are four (4) colour icons a yellow, red, blue and a grey, all which light up...
Here is the link to the manual, it says that the flashing light is PROBABLY caused by lack of toner and the first step is to replace/replenish the corresponding flashing light to the toner. It explains that when the light turns stys on all the time the toner will be empty.
With regards to the paper jamming, there is 3 pages on things to do or try.
I hope this gives you a few ideas
http://www.samsung.com/uk/function/search/espsearchResult.do?keywords=Samsung+CLP-310&input_keyword=Samsung+CLP-310
Nov 30, 2010 | Samsung CLP 300 Laser Printer
PRINT IS FADED HALF THE PAGE IS FADED
Remove toner cartridge and tilt from side to side to redistribute toner. Easy fix to try and usually the correct one.
Apr 20, 2010 | Samsung CLP 300 Laser Printer
The colour prints out fine but the black fades in various area accros down the page
This is the problem in the black developer of the imaging unit. Approach Authorised service center.
Nov 25, 2009 | Samsung CLP 300 Laser Printer
Samsung clp-315 printer stops printing after half page
You'll probably have to replace the exit sensor (lots of people have this problem). Go to YouTube and watch this video: 5fJHykzkfww
You can get the part on eBay for about $10 and it's a fairly simple 15 minute fix.
Sep 22, 2009 | Samsung CLP 315 Laser Printer
My printer has just stopped mid printing, status light is red and the light under the black dot is red suggesting the black toner is the problem. The print on last page printed didn't appear faded and I...
yhe problem is that you exceed the amount off alow data go to printer options and select print from computer (it will be a lot slower) but you will solve your problem
Jul 28, 2009 | Samsung CLP 300 Laser Printer
I get this blue stripe down the right side of the page whenever I print in colour. When I print in black and white the colour is not even but there is no blue stripe.
Open the doors to locate and wipe off the green shiny roller really well. Spin it and wipe it off all the way, especially on that right side. Pull out the cyan toner and wipe it around where the toner comes out. Check other rollers for blue marks and wipes those off as well. Lit free cloths work best but I just use a damp paper towel and then a dry one.
Apr 27, 2009 | Samsung CLP 300 Laser Printer
Can't seem to print the colour red
have you tried updating the printer drivers or cleaning the printer heads on printer properties
Jan 22, 2009 | Samsung CLP 300 Laser Printer
Black toner
I had the problems with white smear type fading on one side of the page , when pritning black, but colour printing seems OK. Did everything suggested in the manual and more. Changed toner. Been working on it a week.  (I got 2000 pages out of that thing).
Now I have the solution. Bin the Samsung and buy a Canon.
Lee
Sep 01, 2008 | Samsung CLP 300 Laser Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP 300 Laser Printer Logo
52 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
