Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
How do you open a Mag Innovision LCD Monitor LT916s ?
I removed the screws at the bottom and the front frame may be pried open a little but it will not come off ... and I do not want to break it with too much force. Please help.
  • 35 Answers
There may be some interior support hooks that keep it together.  look for metal clips between the crease of the front and rear pieces.  Definitely use caution with opening as you do not want to force pressure against the screen.
Posted on Dec 21, 2007
Have a Mag 19" monitor, model LT916s. Screen is
Sounds like a silly question but have you checked the fuse? If it isn't that then it sounds like a problem with the power board. Check it for burn marks and bulging electrolytic capacitors (they're the little round tube like things that stick up), also check any fuses on the board. If it's the caps or a fuse then just replace them, if something else is burnt out then you'd have to replace the board but you might not be able to find a replacement since it's old.
Feb 17, 2011 | Mag Innovision 19" LCD Flat-Panel Monitor...
How to disassemble Mag innovision 19" monitor
Once the 4 screw at the bottom of the screen has been removed the frame surrounding the lcd should slide up and away. The display itself is fastened to the plastic back by 6/8 screws be careful when removing the lcd screen since it is still attached to the electronics in the back by cable connectors!
Feb 27, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
My mag Innovision flat lcd monitor is blank after 3 seconds..
It is not easy. I slip a knife in the bottom edge and slowly work my way around the bottom opening it a little by little. Once you get the bottom and part of each side you can push the plastic towards the top and it will pop off. There are plastic clips holding the bezel down. I always break a couple on opening, but at least the monitor gets fixed. This is not made to open, so good luck.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Power is on but no picture!
Hi...there,
It's seems you guys had a bad lucks! Your backlight inverter are busted. Need to replaced a new inverter...Guys! Have a nice day!
Sep 27, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
LCD MAG Innovision LT916s blak out
Hi...there,
Are you sure you installed to the right side...There (-) side too you know! Also, testing the blue buttons alike caps too....
Jul 15, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor reads no connection
1. Check the cable connection to your PC. It might be disconnected.
2. If your have more then one cable input on your LCD monitor(VGA or DVI) check if you selected correct input; digital for DVI or analog for VGA.
Jun 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
19" Mag Monitor turns 0ff by itself
Hi...there,
All you guys need a new backlight inverter... Your old inverter are busted!
Apr 16, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Screen blacking out.
Hi, I used to fix a monitor from Dell. There are 4 screws at the back of rear panel and no screw at front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off.
For the metal plate that shields the back of the screen, There are some screws you have to deal with. Those screws are at the power and screen connectors.
Thank you,
Tan
Mar 01, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Computers & Internet Logo
141 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
