Question about Dell Computers & Internet
I have just replaced the female power socket on the motherboard of my vostro 1000. it was ripped out, now i need a pict. or a schematic to make sure all parts are in place. where can i find motherboard schematics? or can i?
  • 37 Answers
Try going to dell support site
and click on the manuals
Posted on Oct 05, 2009
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
Vostro 1000 no power
check the AC adapter and power cord. if the power cables are fine. it would mean a motherboard replacement and you need to call the DELL Support team
Dec 30, 2010 | Dell Vostro 1000
My Dell Vostro 1000 could not start from battery. The seems to be OK, but once its in the pc, it wont start. But if I press the switch and hold it before putting in the battery it will start. Mikel from...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 24, 2010 | Computers & Internet
Can't strat up the computer
You don't need to directly go for a new motherboard, but first check/ try with another power supply and make sure you connect the Four Pin Power cable also (it's located at the right corner white in color with four female socket) 20080703220330_05402013467_p5qc.jpg If this doesn't work, check the ram and processor if they are sat fit. Good luck...
Apr 29, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
Everything is unplugged, I just need a wiring schematic to plug everything back in
Does the motherboard have a "purple" socket?
Does your keyboard have a "purple" end?
If so, join the male to the female,
rotating the male until the stiff pins line-up with the holes.
Does the motherboard have a "green" socket?
Does your mouse have a "green" end?
If so, join the male to the female.
The end on the monitor's video-cable has 3 rows of pins;
there's only one place on the computer with 3 rows of holes.
Notice that the sides of the male are tapered,
so that it only fits ONE way into the female.
Similarly, the female end on the power-cord is tapered,
so that it only fits ONE way into the back of the computer.
Note where it connects -- there may be a "rocker" switch,
with a '1' and a '0' on the ends of the rocker.
Press the '0' end down before you reconnect everything.
Press the '1' end down after everything has been reconnected.
Do your PC speakers have a green tip?
If so, then connect the male from the speakers to the green female socket.
Sep 14, 2009 | 3Com Computers & Internet
Heard pop and dell vostro 1000 cut off and will not come back on
Based on the symptoms (Power light on cord is on when not connected to laptop but goes out as soon as you plug it in), the motherboard has to be replaced. YOu may call dell to ask about their out-of-warranty depot or you can call their spare parts sales dept to purchase the motherboard, then find a local tech to replace it.
Jun 16, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1000 won't turn on/no power at all
The power connector within the laptop maybe broken. Not sure about Dell's but many laptops have only solder points holding the internal power connector to the motherboard. With too much agitation, the internal power connector becomes loose and then broken.
More info will help, does a light show on the laptop when it is plugged in? Have you tried removing the battery and lettting the laptop sit for about 10 mins, without any power? Have you re-seated the ram?
These are all possibilities of the symptom you have.
Let me know and G'luck!
Oct 27, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Computers & Internet Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
