Question about Air Tools & Compressors
Model no ml552000 blows the oil out of the air intake when the macine has stopped running, also it sometimes kicks in the power and then free runs until you stop it and restart, under the air filter there is a cylinder that seems to be jamming in the up position ,could this have anything to do with the problem .
  • 41 Answers
So what u do is to check this cylinder under the air filter,your machine is starting on load that y the air compressor kicks while starting and the intake valve is not completely close that y oil comes from the intake valve while stopping
Posted on Oct 03, 2009
2004 dodge durango 5.7 hemi runs real rough white smoke comes out then blows oil cap off.
Ah oh..white smoke is water in the cylinder and cap blowing off is compressed air in the crank case..sounds like you have a blown head gasket or intake or both...have your radiator and block pressure tested..if gasket is leaking it will fail to hold pressure.. Check your oil for water sometimes a bad intake gasket will let water in the oil.good luck..
Sep 20, 2013 | 2004 Dodge Durango
My Bostich 6lb 2 HP oil free compressor was running fine until it kicked while I was using it as it sometimes does and would not stop. It actualy made a high pitch noise and began to smoke for a second...
The regulator on this model is prone to stripping and a kick would do it. Call the toll free number 800.556.6696 with your receipt and you should be able to get a replacement regulator.
Oct 19, 2010 | Stanley FactoryReconditioned Bostitch...
Oil in the air filter ,RANGER 500 2X4/4X4
Has the oil been changed lately? A lot of times over filling the oil will cause oil to blow back thru the carburetor, Also if the air filter got caked with mud running the box with no lid or allot of dirt in the filter. The engine will try to use the crankcase breather hose as an air intake since not enough air was coming in the conventional way, therefore sucking in oil. Has it smoked at all? Sometimes if you try to shut it off oil will run back down the intake tubes into the air box. This may be applicable to your engine that the breather is being used to **** oil into the box due to lack of fresh air intake.
The other possibilities would be crank case pressure pushing the oil in (piston ring blow by), but that should (theoretically) result in low compression (since the cylinder pressure is getting to the crankcase instead of staying in the cylinder), the oil is overfull and being pushed out since air will compress but liquid will not, or poor crank case ventilation system design (but if that were the case likely there would be a recall as that would directly effect emissions which is federally regulated).
Oct 07, 2010 | Polaris ATV
Goodman furnace app 6 yrs old blower only runs app 4 minutes then kicks off does this continuously
You need to remove the blower ,blow it out with a good air compressor. oil if if there is a place. be sure to blow it out once a year. its thermo protected. To stop from burning up the motor.
Aug 17, 2009 | Heating & Cooling
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
White smoke coming out tailpipe
If your intake gaskets are leaking, when you dump soapy water on the gasket, it should bubble like crazy ( when it's running). If you can, run it with the rad cap off and watch for bubbles. If it keeps bubbling, you probably have a head gasket problem.
May 14, 2009 | 1996 Chevrolet Cavalier
1991 Subaru Loyale- oil in air intake
There are only a few things that cause oil in the intake, most common is a plugged PCV (Positive Crankcase ventilation Valve), this causes pressure to build from the combustion process and forces oil into the air cleaner/air intake system, and in some cases out the oil seals, another issue is excessive engine blow-by, this is when the piston rings don't seal anymore and the pressure once again builds and forces oil into the air intake, the last and easiest to fix is an overfilled crankcase. Excessive oil burning of any kind will destroy the catalytic converter in a short period of time. How many many miles on the car, does it have excessive blow-by?
Nov 14, 2008 | 1991 Subaru Loyale
Air Tools & Compressors Logo
55 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
