Question about Water Heaters
My boiler will not fire up the pilot light is on, the thermostat clicks when asking for heat but boiler will not go on. What could be the problem ?
  • 454 Answers
Best case, the gas selector switch is set to the pilot position. Rotate it to the full open position to allow the boiler to fire. If it is already in the normal operating position, you will probably need to replace the gas valve.
Posted on Oct 04, 2009
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
No Heat. Replaced the gas control valve. Pilot burning OK
Try bleeding the gas line to the valve. They are always full of air after a valve replacement. BE CAREFUL!!!!!!!!!!!! Gas is explosive!!!! Does the valve "click" when the stat calls for heat? If not, check the wiring.
Dec 12, 2013 | Water Heaters
Boiler on hot water radiator system wont work
This is both a complex and dangerous system. There are many factors which can cause this. I will need more information. I will ask some basic questions... Was the thermostat changed out with the a/c unit or does it have a separate one? Did the gas valve get shut off? Did the breaker get shut off? Is the water on? They have low water lockouts. 99% of the time, it is where work was done. Did they hook up the stat correctly and establish the proper type of heat on the stat? Is the circulation pump on? Is the flame control board reset tripped? Leave feedback and we can go from there.
Nov 13, 2013 | Water Heaters
When my boiler pilot light starts up it kicks out straight way and knocks off the boiler seems to have no faulty parts
Pilot lights have a metal detector just above them, which heats up when the flame is on. If that is not switching fully, Boiler will think no flame and close down. It is a safety feature, but if faulty will stop boiler firing, might just need adjusting, but may also need to be replaced, not really recommended as a diy job
Mar 04, 2013 | Water Heaters
Water not hot even thermostate turned to high. The pilot light is on. Shoulder I be able to visualise the burner actually firing.,or hear it firing. I can see the pilot light clearly. Please help
If you have cold water now, you should hear the unit fire up and run while heating water. Proceedure would be; pilot is lit with thermostat at pilot setting. Once pilot is lit, you turn up to desired temp setting and you should hear the heater running. Depending on lighting, you should be able to see it slightly brighter and may flicker some while heating.
Apr 25, 2011 | Rheem Water Heaters
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
Water heater pilot light
it also sounds as though the pilot injector could be blocked so when the boiler comes on it extinguishes the pilot & then when the burner goes off boiler shuts down, or also the pilot rate maynot be set right, so when the main burner kicks in it robs the pilot of the gas it requires.
It could be that, or there is lack of ventilation for the boiler, so you get flame lift off when the boiler fires?
Dec 14, 2008 | Water Heaters
Water Heaters Logo
210 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
