Question about Maytag Dryers
My gas dryer clicks when the heat is supposed to come on.
  • jvsky Oct 06, 2009
    Therre is no coil, it's a gas jet.
  • 63 Answers
Replace the coils
Posted on Oct 03, 2009
Testimonial: "Didn't know the parts were called coils. Thanks. "
Why does my gas dryer heat for 30 sec then i hear a click and the gas shuts off?
It's not supposed to run continually, there is a thermostat inside that regulates the temperature to about 130-150F, if it's not in that range you might need to change the cycle thermostat.
Aug 06, 2014 | Speed Queen AGS28AWF Gas Dryer
The dryer isn't drying. The dryer is a kitchen aid the model is kgye777bwh2. Also this is a gas model. I noticed that the pilot isn't lighting when I turn on the dryer. With the dryer running i...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 22, 2011 | Dryers
My ge dryer model dpgt750ec1pl is running but no heat i was wondering if this style dryer is suppose to show some fault codes i thought it was the heat assembly but since itsnot showing any codes i thought...
heatman101./
Apr 25, 2011 | GE Profile Harmony DPGT750EC Electric...
Dryer wont get warm... intermittently works... sometimes canhear the ignitor spark, sometimes not. Completely cleaned all of the lint in the machine, exhaust line, etc... and got alot of lint. Thought it...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
NO HEAT
Check out this tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 28, 2010 | Dryers
My whirlpool gas dryer will not heat. It only spins.
If the dryer won't heat but does run, it is more likely to be the gas ignitor assembly, assuming there is gas available to the dryer. If the thermal fuse was bad, the dryer wouldn't start at all.
Jan 06, 2010 | Dryers
Whirlpool gas dryer LG6151XSWO...won't heat. I
THE MOST COMMUN THINS IS THE THERMAL FUSE!!! CHECK IT AND REPLACE IT IF NECESSARY!!
Oct 05, 2009 | Dryers
Gas dryer heats for 10 minutes then heat goes off
it's doing what it's supposed to do. you should use a different setting.
Sep 07, 2009 | Dryers
Maytag Gas Dryer MDG8600AWW does not heat up. Could it be the glow bar ignition? When the dryer was beginning to fail, it would heat up for a few minutes then the heat would die. Now it doesn't heat up at...
If it was heating occasionally after you first noticed the problem, most likely not the ignition glow element. I am having the same problem and am looking at replacing the gas valve. I used to be a Sears Repairman. I verified that both magnetic coils are energizing when they are supposed to, but often the gas won't flow. Also, I hear a clicking noise internally on the gas valve.
Sep 01, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
