Question about Apple Audio Players & Recorders
Hi, my BMW 1 series has an aux jack problem
Hi, my BMW 1 series has an aux jack 3.5mm to 3.5mm but I can't seem to get anything from it. With my Ipod pluged in and I press the mode button it just says NO CD; its like theres no facility or seeing the source. Has any body had this or am I doing something wrong?
2 Suggested Answers
SOURCE: my kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Posted on Nov 12, 2012
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
Can connect a ipod to pld2000
yes you can connect it
http://www.eseelectronics.com/html/pld2000sec.html#
does the back look like this?
if so then go to ebay or any other electronics shop and buy a ipod cable
3.5mm jack >>>>>> phono jack (red, white)
with this connect the phono jacks to the audio in, in AUX 1 and select AUX 1 on the system and plug in your ipod to the 3.5mm jack and play
May 10, 2010 | Teac PLD2000 System
What jack is compatible to laptop using shure
You have to connect the unbalanced output (the 6.3mm jack) to the laptop's line in (or mic with setting the rec level at very low settings) 3.5mm jack. In details the wiring should be as follows:
6,3mm jack shield to 3,5mm jack shield
6,3mm jack ring to 3,5mm jack shield
6,3mm jack tip to 3,5mm jack tip and ring
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 12, 2010 | Shure PGX14 Wireless Guitar/Bass System...
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
Trying to sort aux-in
as you do not mention the model I have to guess that your player has a aux-in on phono (or RCA) jack. If you want to plug the iPod just buy a "Twin phono to 3.5mm stereo jack cable".
You can find in many superstores or Maplin.
Mar 30, 2008 | Audio Players & Recorders
Got an aux cord to plug my ipod in, doesnt switch to "aux in" mode
According to the manual, you need to "enable" the AUX 1 or 2 thru the initial settings menu.
Press and hold the SRC until the unit turns off. Then press and hold the MULTI CONTROL (knob) until the Language appears. Turn the knob to cycle thru the options, select AUX 1 or 2 and press the knob again to select ON.
After selecting them to on, power the unit on and press the SRC to cycle thru the sources to find AUX 1 or 2.
The owners manual is here if you need it;
http://www.pioneerelectronics.com/pna/v3/pg/support/details/0,,2076_310070337_338818745,00.html
Best of Luck.
Nov 18, 2007 | Pioneer DEH-P6900UB CD Player
723 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
