Video machine has one scart plug - television set
Video machine has one scart plug - television set has 2 hdmi sockets.is there a suitable cable to solve this problem.
  • 58 Answers
If your TV has No Scart Socket, it may have a Composite socket (Yellow) and an Analog Audio input (Red and White).
You can buy a Scart to Phono lead suitable for the job easily.
HDMI is no use to you with video. Get a PVR for future use, make life simple.
Posted on Oct 03, 2009
KEEP GETTING MESSAGE ON TV (RGB ON TV SCART HAS BEEN ENABLED)
trouble shooting common problems when using RGB ...
https://www.retrogamingcables.co.uk/trouble-shooting-guide-for-rgb-sca...
No video or sound on tv when using RGB SCART cable. Check that the SCART socket you have plugged the SCART cable into is an RGB enabled port (this is ... Some TVsets display an 'RGB' message in the top right of the screen for a short ...
SCART - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/SCART
WikipediaThe signals carried by SCART include both composite and RGB (with composite ... A VCR will often have two SCART sockets, to connect it to the TV ("up", ... SCART enables a device to command the TV to very quickly switch between signals, ... The box can instead ask the TV to stop displaying the normal signal and ...
How to use your TV as a computer monitor for gaming, videos
www.cnet.com > Home Entertainment
CNETJan 26, 2012 - Many modern video cards have an HDMI output. ... The trick, of course, is finding a TV with RGB-PC inputs. ... You can also send him a message on Twitter: @TechWriterGeoff. ... (Or just enable game/graphic mode) ... As yet I've been unable to find anything online that lists TVs that do or don't work with PCs ...
Scart fully RGB enabled? ' AVForums
Feb 09, 2016 | Televison & Video
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
How can I connect my dvd player to a Philips 32PFL5605H/05 32-inch Widescreen Full HD LED TV ? It is of the type which has one red, one yellow, and one white connector but i do not see any sockets that...
The included cable with the red, yellow and white RCA connectors is a composite A/V cable. To connect this cable to the TV, you need a SCART-cinch adapter. Then use one of the SCART connections on the TV. Note: the SCART connection does not handle HD signal.
You will get a much better picture if you buy a different cable. Depending on your DVD player, get either an HDMI cable or a pair of cables - a component video and audio cable. (Both component and the audio cable will have RCA plugs at each end. The component video has 3 plugs - red, blue and green. The audio will have 2 plugs - white and red.) Both of these will carry HD signals. Most DVD players will have at least component video and composite video jacks; some have the HDMI output. Most DVD/VCR combinations will need the composite video for the VCR and the component video is optional for the DVD signal.
I hope this helps.
Dec 24, 2010 | Philips Televison & Video
I can't seem to get it to record any shows off my t.v.
the hdmi connections are input only.
if the tv has scart sockets on the back, and the recorder also, connect to these. the tv's scart needs to be either 2 way or out put shown with an arrow pointing out of a box for output and a 2way arrow for 2way scart.usually scart socket 2 is 2way. set the recorder as you would normally but set the channel to tye av or scart that you are using. please note that video plus will not work on the scart socket. you may also have to set the output for the scart socket via the menu.
Mar 12, 2010 | Televison & Video
Lg 42' lcd cant get video signal i can get sound and menu pictures all come up. but no output from cable or ps3
I guess your either using the scart socket or the HDMI socket. You have gone into the menu and changed your input source to either HDMI or Scart havent you? Does your TV aerial input work when switched to Antenna on the input source menu. If these dont happen then you have a faulty main pcb.
Feb 13, 2010 | LG 42LH40 LCD TV
Connecting the DVD-v9800 vcr to the T260HD tv monitor
Does it have a scart socket. If it does you can get a scart cable with a scart on one end and phono plugs etc or the other.
Jan 12, 2010 | Samsung DVD-V9800 DVD Player/VCR
I bought a PS3 slim (120 gb) recently, & only have the one game so far - FIFA 10. For some reason when we play it with the HDMI cable connected to the t.v the gameplay is noticeably slower than when...
buddy lsn, go to the settings its in the left side of the main menu, there is an option about the game settings, video settings, audio settings... etc. now go inside every one of them and change the default setting to be suitable with HDMI okkkkk :))) if u still cant find it send me back and i will right down in details what should u do exactly cuz idont memories the menu :S looooooool
Dec 05, 2009 | Sony Playstation 3 (PS3) Console
LG 42PC56 ps3 best settings?
Your PS3 should detect when you set up a HDMI connection then just follow the onscreen instructions. If it does'nt unplug the HDMI cable and use the scart cable. Then unplug the scart cable and plug in the HDMI cable your PS3 should detect this HDMI cable and it will notify you on screen.
Hope this helps
Terry
Apr 06, 2009 | LG 42PC5D Television
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
