To fix the error by editing the registry, perform the following steps:
Exit and close all applications currently running on your PC.
On Start > Run type Regedit and press the Enter key.
Next, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries if they exist under this key:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Preventing System Errors
To prevent frequent system errors on your system, you must take care of the following:
Be a vigilant and aware user by being careful about the websites you visit and the email attachments you open.
Do not visit dubious websites and do not open attachments that come with unsolicited mails.
Implement antivirus and antispyware programs on your system, keep them updated, and run them regularly to prevent any malware infestation on your PC.
Keep your operating system, device drivers, and installed
applications updated with the latest patches and security updates
released by their manufacturers.
Use system utilities included with your Windows system to perform regular system maintenance.
Use a good registry cleaner such as RegGenie to regularly scan and fix registry problems.
Next, navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
My wife was playing Sims 2 Double Deluxe on her daughter's character. lol She ended up setting her...
(More)
My wife was playing Sims 2 Double Deluxe on her daughter's character. lol She ended up setting her daughter's boyfriend on fire on the game and exited without saving so he wouldn't get killed. Now... when she tried to restart the game it would work and kept giving her the message "No disc inserted. Please insert the original "The Sims? 2 Double Deluxe" CD/DVD." and would give the options "Retry" or "Cancel". So I got on and started looking it over. Got the same results she did. I restarted. Nothing changed. I went to the device manager to check the status of the driver and also tried reinstalling the driver. Everything checked out ok from the beginning but even though I did reinstall the driver that still did not fix the problem. I used my Laser Lens Cleaner DVD but I doubt it did much good because the drive wont keep the disc rotating long enough to do its job. I did find one disc that's working. It's a Hoyle Board Games CD. Its icon doesn't show up on the DVD/CD Rom drive location and it doesn't run automatically when I put it in but if I activate it from the desktop with the shortcut it runs fine. Can't figure this out for the life of me. I've never seen this happen before. I'm Running Windows XP Media Center Edition SP3 on an HP Pavilion a1473w. The drive is a Lightscribe DVD +/- writer /CD-writer Thank you for any help you can offer!
How to transfer lightscribe data to a pc and add merge other files to create one permanent...
(More)
How to transfer lightscribe data to a pc and add merge other files to create one permanent electronic master
Have an ASUS p5kpl-cm MB. The HP DVD writer 1140d will not show up as installed, ''This device...
(More)
Have an ASUS p5kpl-cm MB. The HP DVD writer 1140d will not show up as installed, ''This device cannot start. (Code 10)''. I have uninstalled and tried to update the driver through Device Manager.
