Question about Craftsman 24 Hp 48" Deck Yard Tractor
I need to replace the shaft that connects to the blade on my Craftsman?s Riding Mower 42?. The problem is the star that holds the blade is place has smoothed down. So, I cannot use the blade to hold the shaft in place when losing the bolt at the top of the shaft and pulley. Any tricks or suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 143 Answers
You can use the belt to hold the pulley from turning
( you ARE going to replace the belt aren't you?)
Simply use locking pliers (vise grip) to clamp the belt sides together close to the pulley. Then wra the other other end of the loop around something convenient to keep the pulley from turning. Guaranteed to hold the ******.
Posted on Oct 03, 2009
Testimonial: "Great Job! It work just as you said. The only thing I would add use a impact wrench is only way getting the nut off. A 3/4" socket did not move it."
  • 389 Answers
The pulley itself is splined onto the shaft by virtue of a multi-point star. You can use a LARGE pair of channel lock pliers to hold the pulley as long as you are careful not to damage the pulley. You also may be able to squeeze the belt tight around the pulley with standard channel lock pliers enough to get the nut off
How do you replace the blades on a 42 in. deck? do they need to be placed in a special way?
use the blades for leverage when loosening the bolts. when putting new blades on, hold the blade in the star center hub install washer and bolt. use blade for leverage when tightening.
Jun 23, 2014 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Remove mower spindle star is stripped blade moves
If star is actually stripped, you will have to replace the whole spindle assembly and blade. I would not change just the shaft if I was you as its almost as expensive as the whole assembly.
Jun 07, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lt 2000, blade not staying in place
i would need a complete sears model number to look this up for you, however, you will need to remove the intire blade spindle housing, then you can remove just the shaft from the housing. and just replace the shaft. Will save a lt of money.
if you can find the complete model number you can go on the internet to
mtd.com/parts or to ayp.com/parts
and you can pull up a parts diagram and find the exact part number and order it online, or take model number to sears and they will either have it in stock or can order it for you. Sears will however cost you a fair amount more then ordering online. I hope this helps you
May 28, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Duel blades on craftsman riding mower cut unevenly
check the front tire air pressures then for a bent blade
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
The star mounts on my poulan 42'' riding lawn mower
Without knowing your mower for sure, I think I know what you may need to do. Most often, you just need to remove the block that the pattern is on. These are most often bolted onto the shaft. If you don't have your parts book for your mower, you may bee able to look it up online.
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Concerning a Craftsman 24hp garden tractor. The
Hello jejodaro:
>>You have to Hold the Shaft on the Blade Side with a Pipe or Strap Wrench or Depending on the Model, you can Block the Blade an Hold the Shaft so the Pulley Nut can be Loosened/Removed.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy. Thanks.
Respectfully
John
Mar 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Sep 03, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 24 Hp 48" Deck Yard Tractor Logo
124 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
