Question about Whirlpool Calypso GVW9959K Top Load Washer
I have 2x4 ft. bathroom rugs in a machine on which I have just paid $300 to have the outer circle and rubber gasket of the agitator repaired in the past week. It is now giving me an LD message each time I unplug it, restart it on either normal cycle or rinse and spin (where it originally gave the LD - just before the rinse and spin). I have tried this several times at the suggestion of a repairman when it was doing this a number of months ago.
    President:
  • 1,865 Answers
LD error means the lid switch is not activated. Maybe the switch is loose or needs replacement
Posted on Oct 03, 2009
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes from washer almost always have big pieces of lint on them. Is there a filter that can be accessed?
The last time I saw one with this problem a lady had washed a big rug in there and the rubber backing came off. had to remove the pump and drain hoe to flush all of the junk out. Their is no filter on these machines.Remove the agitator and get the basket out. Then take the pump and drain hose out and flush out the junk. themobilian_2277.jpgthemobilian_10.jpegthemobilian_2278.jpgthemobilian_2280.jpg
How it works with manual HERE
More here
May 02, 2011 | Whirlpool 3.2 Cu. Ft. Super Capacity Plus...
I have a Whirlpool thin twin and the agitator is not spinning and makes a humming noise. I washed a small bathroom rug that created an uneven load and this is when the problem started. We removed the top...
I don't have a solution to this but I have almost the exact same problem - washed a runner bathroom rug last night, today it drains but won't spin and I'm having trouble diagnosing further or disassembling... <!-- from fixya rte -->
May 13, 2010 | Washing Machines
Maytag epic z-ripped piece of door seal
I would say that the rubber may have gone into the system, and is probably clogging up the water outlet hose, and or the Pump. This is a bit of a "Fix' it will require the taking off of the motor and Hoses, connected to see where that bit of rubber is.http://www.letsfixit.co.uk/html/washing_machine_faq.html
http://www.appliancerepair.net/apnet/frameset?http://www.appliancerepair.net/apnet/washer/toc.htm
If you do not choose to repair this yourself, using those links above. Then please get a "Quote" for repair.
Mar 24, 2010 | Maytag EPICz 3.7 cu. ft. Washer
Will not preform final spin
What is this machine? If whirlpool you need to check the drect drive motor couple. they break when bathroom rugs with the rubber on bottom that cause this about 90% of the time.
Mar 13, 2009 | Washing Machines
Removal of agitator
I gotta congratulate you for taking on the toughest job on your washer. The transmission replacement is daunting if you've never done one before.
OK... about your question.
Here's a place with detailed instructions (and pictures) on how to do the 2X4 trick. If after doing that you still can't get it, then try tapping (actually a little more than just "tapping") the agitator with a rubber mallet. This will (hopefully) loosen any rust on the splined shaft allowing the 2X4 to do its' job.
As a last resort, you can get yourself an "Agi-Tamer". It's a tool that we in the appliance repair biz use for just this problem. It's a snazzy little gizmo that fits between the bottom of the agitator and the tub. It has a water hose connected to it... you then take that hose and put it on the cold water valve behind the washer. Then you slowly open the valve filling the Agi-Tamer with water. As it fills, it expands and forces the agitator to lift with it. You have to be careful, though. I've seen agitators fly off the shaft like a cork from a champagne bottle! So if you go this route, put your 2X4 over the agitator as the Agi-Tamer fills to keep it from flying, OK?
(*NOTE* ---> the link to the Agi-Tamer above shows one designed to use air pressure, not water (like the one I use). I've never used one with air, but it appears that it'll hook up to a bicycle tire pump or one of those inflatable swimming pool toy electric pumps. Just a word of caution here... knowing what I do about Hydraulics and Pneumatics, the pneumatic model WILL MOST DEFINITELY BLOW THE AGITATOR OFF THE SHAFT!!! So, take care if you use that model, OK?
Now where to get one. This is a specialty tool sold to appliance repair guys (and girls... although I've never HEARD of an appliance repair girl). You may try calling a local appliance parts retailer and see if they have one in stock or look around on the web. They run about $50, so it's kinda pricey to buy it only to be using it once... why not call an appliance repair company and explain what you're trying to do. Ask them if any of their technicians carry an Agi-Tamer on board their sevice vans. Then maybe work out a deal to rent it or borrow it. Or you may simply schedule one of their technicians to come over and remove the agitator FOR you. <--- That's probably the way to go, btw. Using an Agi-Tamer is kinda dangerous and a reputable company might not want to take on the liability of you using one of theirs just in case you poke your eye out or something.
So there ya go, KR! I hope this solution was satisfactory for you and that it helps you get that pesky agitator off. If it did, please remember to rate me as "it solved my problem", deal?
SG
Jan 10, 2009 | General Electric WHDRE526EWW Top Load...
Bathroom door will NOT close because rug is too thick
remove from the hinges, mark up the neded amount and cut with a saw. its that or youl need thinner rugs
Dec 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Small rug washing in front end loader washer
its problably not able to balenbace the load of rugs, if the machine cant balance itwont go to high speed spin. in actuallity your probalby better off bringing the rugs to the laundry mats, especially if the are rubber backed, the rubber backing will come off clogging your pump assy, then your looking at replacing hte pump for a few hundred dollars, for a clean set of $30 bath rugs.
Nov 30, 2008 | Frigidaire GLTF2940ES Front Load Washer
Admiral washer lnc6160b71
If you mean the inner drum - remove the agitator, pull off the sofetener cup and remove the 15mm bolt down inside to remove agitator, then secure inner drum to center bearing.
If you mean the outer drum, check the holding down springs visually, remove the front panel by inserting a flat blade approx 4" from each side at the front to release clips, then remove 2 small bolts to remove front panel.
Also check and replace drive belt, tilt machine backwards to gain access underneath.
Jul 15, 2008 | Admiral AW22 Top Load Washer
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
