Question about Roper REX4634KQ Electric Dryer
Does not heat.. checked heating element and it tested good. what elese could it be
    Genius:
  • Roper Master
  • 1,474 Answers
Thermostat or wiring, have yooou got voltage to heater?. Be very carefull when checking this dont want you to get Free perm...
Posted on Oct 03, 2009
Heated driver seat doesn't heat on 2001 Buick Regal GS
You have probably burnt up the element as it is a 17 year old seat now. The elements are replaceable, but the labor is pretty spendy. To test it you will need a multimeter to check for continuity across the connectors that go to the seat heating elements and check for voltage at the car side of the connector. If you have 12v to one side of the connector and continuity to ground at the other side, and do not have continuity to the seat side between the connectors, you know it is a bad element.
Jan 02, 2018 | Buick Cars & Trucks
We can't get our hot tub to heat. The heater light comes on but the heater still won't heat.
heating elements are resistors that get hot
one end will have 115 volts but the other end should be considerable less because the resistance of the heating element drops the voltage
if you used a ohm meter you should be reading a resistance of 500-1000 ohms for a good heater element but with your readings , there will be no resistance so the element is faulty
Apr 06, 2017 | Element Water Heaters
Intermittent No Heat
if you checked all the t-stats and they checked good the only two things left is the board and the motor,it takes 240 volts to get heat 120 comes from the board and the other 120 volts comes from the motor,first go to the block where the cord connects to the dryer and make sure you have 240 volts there,but you say you changed the thermister and you had heat?check both thermisters to see if you get the same reading on them both should be around 10k ohms,that could of been coincidental With the resistance value at room temp on the thermistor being good then this would not be a thermistor error. There are 2 components other than the thermostats which would cause the heating element not to work. First is the motor and second the Control board. The best option is to disconnect the power to the unit and access the heating element. Disconnect one wire that is going to the heating element, preferably the one on the thermostat side. Plug the unit back up and using a multimeter you will want to turn the dryer on and test for 120 vac at the terminal on the heater where the wire was disconnected. What this will do is eliminate the heater element itself and the motor. If there is 120 vac at this point then you know the heater is good and the motor is good because the other 120 vac coming through the thermostats is the control board side of the circuit. If there is not 120 vac at that point then you will want to test the other terminal on the heater and check for 120 vac. If there is not 120 vac then the motor would be bad .
Feb 01, 2018 | Whirlpool GEW9250 Electric Dryer
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    My dryer does not heat up? how do you check the heating element? Model #DE27T3WXFB
    Hello there and thank you for choosing fixya
    Please Closly check the following
    Dryer tumbles, but there is no heat
    Dryer takes too long
    • Check the lint trap
    • Check for proper air flow
    • Inspect the vent hose for kinks or dips
    • Test the heating element
    • Test the thermostats
    Jun 29, 2011 | Dryers
    Dryer won't heat
    Well first all you may check out the heating element, it is possible that your dryer isn't heating because its heating element is defective. Heating elements are not repairable. You need to open your dryer's cabinet and locate the heating element so that you can test it. and you need a multimeter to check it out. Secondly you may check out the Thermal Fuse Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you need to replace it. Post further comments for further help or information.......
    Good Luck!!
    Thanks for using FixYa!!
    Jan 26, 2011 | Kenmore HE5 Electric Dryer
    Whirlpool duet electric wil not heat
    Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
    Jul 30, 2009 | Whirlpool GEW9250 Electric Dryer
    Heating element continuity?
    Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
    Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
    Mar 11, 2009 | Kenmore 62602 Electric Dryer
    Roper REX4634KQ Electric Dryer Logo
    Top Roper Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Roper Dryer Expert? Answer questions, earn points and help others
