Question about Garden
WHEN I MOW FOR ABOUT 15 MINUTES, ENGINE STARTS LOPEING, RUNNING ERRACTIC AND SHUTS OFF. TRY TO START AGAIN, WON'T START. SEEMS LIKE WHENS IT'S COOL WILL RUN FOR AWHILE. LAWN BOY 21'' CUT, WALK BEHIND SENSASPEED. 6.5HP, 4 CYCLE TECUMSEH
  • 87 Answers
On the side of your mower by the exhaust, there should be a plastic cover about 2"wide by 3" long, inside of this is your air filter take it out & clean it with a air blow gun, or tap it until clean, see if that helps.
Posted on Oct 03, 2009
02 mercury sables starts but within 6 minutes shuts completely down. Won't start for bout 15 minutes later then shuts down again.
Something electronic is overheating , transistor , . the engine computer , ignition module . crankshaft position sensor. Also check PCM power relay . losing power . Check for spark , fuel pressure when it stops running , see what is missing .
Jun 21, 2016 | Mercury Cars & Trucks
I have a cub 5252 tractor/mower. I run the pto and mow for about 30-45 minutes and the blades stop as gauges go to off position while engine keeps running. The gauges come back up, but pto will not come...
This is a sign that the back of the console is getting too hot. There have been cases that the console has melted and it costs several hundred dollars to replace.
Jun 13, 2014 | Garden
2000 Mercedes CLK..I think it is a vapor lock problem..car starts as usual but 5-7 minutes later it just shuts down..happened in traffic..so I dont dare to drive it..Afterwards it doesnt start unril...
Sounds like the crankshaft position sensor needs to be replaced. They are a common problem with the Mercedes. That sensor is the one that the engine control module looks at to see if the engine is running. When they get hot and stop producing a signal the engine control module thinks the engine is not running and shuts of the fuel. After waiting awhile they cool down and the vehicle will start up again. I've changed many of them when I worked at the dealer. Tricky part is when there working and the car is running there will be no check engine light on or code stored. Usually will only have the code when the car won't start. Let me know what you end up finding out on it but that would be the first place to look and probably the cheapest.
Apr 20, 2011 | 2000 Mercedes-Benz CLK
Car starts...then when dies after a minute or two
when engine is warm grab the rad hose's if thay are hot coolant is moving in the engine i would think it would be a temp sensor
Nov 10, 2009 | 1988 Volvo 740
Engine shuts off after about 10 minutes of use
Try loosening the gasoline cap on the engine. My snowblower acted the same way until a mechanic told me it sounds like the engine is not getting enough air. Some gasoline cap vents go bad and starve the engine. If your engine continues to run you can buy a new gas cap.
Mar 12, 2009 | Briggs & Stratton Garden
Garden Logo
256 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
