Question about Technics SL-1210 Turntable
Major Hiss I've just got an SL-1210 hooked up to a Technics VX500 amp.  I've adjusted for the moving magnet cartridge it's got but there's a really strong hiss running through everything.  I've got the earth hooked up too.  I removed the cartridge and all the wires are intact.
  • 515 Answers
The issue could be 1 of 3 things...
1) Cartridge / Headshell
2) Tonearm
3) RCA cables
or a combination.
Hard to isolate the issue. Make sure the cartridge/headshell wires are connected properly. Does the his go away when you touch the tonearm? How about the RCA cables? If so, then that is usually the culprit. Did you buy this new or used? If new, I would suggest returning it, or excersizing the warranty.
If the tonearm is the issue, this is not something I would suggest you replace on your own, as it is rather complicated.
Here is a site to buy all the parts you need for your unit:
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
Just pick the model you need parts for. You can use any good quality RCA cables, but soldering is required in order to replace.
Hope this helps.
DJPROAUDIO
TWEAK AV LAB
Posted on Jan 19, 2008
What pre amp do i need too conect my nad L 75 to
Any that has a magnetic cartridge pre-amp built in.
Jan 31, 2014 | Technics SL-1210 Turntable
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
Mar 29, 2013 | Technics Audio Players & Recorders
I wired my technics 1210 turntable up to my usual audio set up and although it shows itself to be working, there's no sound coming from the speakers. Can anyone shed light on this?
First put your finger on the audio imputs for the deck in your amp. They should buzz with the amp switched on. If you can't get them to buzz, then the magnetic cartridge pre-amp in your amp has failed. If they do buzz. Take the wires to the cartridge off (make a note of where each one fits). Then with the amp powered up and deck plugged into it. Touch each wire one at a time with your finger. You should hear a buzz on two wires (one on the left one on the right) and nothing (much anyway) on the other two. If you don't hear any buzz there's something wrong with the connection cables to the amp. If you do hear the buzz, then the cartridge is dead.
Feb 15, 2011 | Technics SL-1210 Turntable
My technic 1210 is only playing through one channel can you help with telling me how to repair
First disconect the wires to the cartridge. With you amp on, touch each wire one at a time. You should hear a buzz on two of the wires (one one ach channel) and nothing on the other two. If you do hear the buzz on both channels the cartridge has failed or the connection to it is poor. If you are still missing a channel then the problem lies in either what connects the two devices, or the magnetic cartridge pre-amp inside the amp. If you put the good channel phono plug in the other bad channel of the amp and don't hear any sound it is the magnetic cartridge pre-amp that has failed.
Nov 15, 2010 | Panasonic Technics SL-1210MK2 Turntable
The rca outputs on my table are putting almost no signal out...if i turn my mixer way up then i can hear faintly...is there a soundboard gone bad?
Check that your mixer/amp has a magnetic cartridge pre-amp. If it doesn't you will need to get one. If it has first remove the wires to the cartridge. If you touch them one at a time, with the amp/mixer on. You should hear a buzz on two of the wires (one left one right). If you do the cartridge has gone. If you don't the mixer or amp has gone.
Nov 07, 2010 | Technics SL-1210 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
How do i free up the tononig arm on a technics 1210 deck? It is stiff and wont move across the record.
It should really be replaced but you can try adjusting the screw on the top of the arm
Dec 23, 2009 | Technics SL-1210 Turntable
Is a Vestax VR-3S cartridge compatible with a Technics 1200 turntable?
HI!
I understand the Vestax VR-3S cartridge is moving magnet (magnetic). Provided it is wired correctly there should be no problems. Any magnetic cartridge will be compatible.
CHEERS :-)
Aug 09, 2009 | Technics SL-1200 Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
256 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
