I have two problems. 1. The dvd drive is not recognized by my Vista Home Opersating System. 2. I can not disable the touch pad. FN+F9 does not do it. I even deleted the driver. Pad still works, cursor still jumps all over the place when typing. I really hate this.
  • 2 more comments
  • Maxl Xavier Buhanan Oct 03, 2009
    ok..I have gone through this before. I will try again. How do you get to BIOS?
    The touch pad is ALPS and in device manager I saw no box to disable.
    Problem 1. has been resolved. I went to the link and allowed the system to automatically fix it. I should have done this before.
    Problem 2 is not fixed. I saw ALPS before and now I see Synaptic PS/2. This confuses me. Where do you see the actual device name? I am in device manager now.
  • Maxl Xavier Buhanan Oct 04, 2009
    I was able to resolve the problem.
    Thank you.
  • 3,940 Answers
OK, both are fairly easy to resolve.
1. The DVD drive. Make sure drive is seen and identified in the BIOS. If it is, then issue is software. If it is not see or listed an an UNKNOWN device in BIOS, it is a hardware issue. If not seen, unknown, then reseat the drive/drive cables and see if it ID's. If drive does not ID in BIOS, it will need replacement.
If drive is ID's in BIOS, then boot to windows and run the fixit utility from this link: http://support.microsoft.com/kb/314060
after rebooting the drive should be seen in My computer and a drive letter assigned.
2. Touchpad jumping. since touchpads are native to Vista, it will work without the driver, just not have advanced functions. One of the advanced functions of the driver will resolve the typing jump issue. Reinstall the touchpad driver, then on control panel, mouse, in the touchpad settings, there should be options to disable the touchpad while typing. It may be listed as PALMCHECK, or Disable when typing depending on the driver (ALPS or SYNAPTICS) If you are using an external mouse then there also may be options in the touchpad settings to disable when USB pointing device is attached or you can disable the touchpad in device manager as a last resort.
Posted on Oct 03, 2009
  • IQUIT Oct 03, 2009
    What brand/model is the system?
I want to disable my touch pad.
There may be an Fn-Key combination that allows you to toggle between ON and OFF. (maybe Fn-F9). The relevant key should have a picture of a touch pad.
Apr 22, 2012 | Computers & Internet
First at all, I'm sorry about my terrible Eng. I have a HP 6720s laptop and there is a problem with touchpad. How can I disable the touchpad with 'fn' key? I looked every pages on my...
OK to disable you Touchpad you can press Fn + F12 or you can go to Control panel...Search for devices...or you can go to Device Manager. In the menu Look for sp/1 or sp/2 it will have your installed components or drive information for you mouse pad/touch pad. You can right click it and disable it. Also if you are having problems with you Touch Pad you can also download the driver and re-install in on your drive.
Go to this website: CLick Here For Hp Synaptics Drivers.
Click Your OS,
Search For Synaptics driver.
May 24, 2011 | Computers & Internet
Touch pad is not responding
depending on the model. right aboce it there could be a little button that looks like the toch bad with a line through it. press that and try again.
on another model there was a touch pad icon in the system tray. click that to disable the touchpad. might need an external mouse to do it.
Feb 25, 2011 | Acer Computers & Internet
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Toshiba satellite a215 disable mouse pad, is this possible.g
I think you meant touch pad. so on every Toshiba notebook Touch Pad can be disabled on two different ways. The first one is using FN+F9 key combination or using DISABLE option in mouse properties.
Nov 26, 2009 | Computers & Internet
I have an Asus K60 Laptop.I can not figure out how to turn off the touch pad, as I am using a wireless external mouse instead of the touchpad on the laptop.Any clues?
Did you try the FN key and F9...
That is what they say to disable your touchpad
You have a function key which is called Fn That key allows you to use the functions on the F series keys
So Fn then F9 should do the trick
Nov 08, 2009 | ASUS Computers & Internet
Mouse pad frozen
Please try the following to fix the problem,
1.) Did we accidently press the button to 'enable/Disable' the touch pad/mouse?, for most of the machines its fn-f9.
2.) Try plugging in an external mouse to see if you can get back your mouse functionality.
3.) There can be a problem with the touch pad, try reinstalling the drivers again.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | ASUS Eee PC 900HA Notebook
Asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Mar 16, 2009 | Computers & Internet
Disable Touch pad device
Hi NR5A,
Press Fn+F9 on your keyboard to enable/disable
Goodluck,takecare.
May 08, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
