My tv is about 12 yrs old. it is a 32 '' when it warms up the picture goes out. as soon as it cools of it will restart, but only for a few seconds
  • 58 Answers
Get a new TV, they are cheap enough now. It sounds like you have a Solder Joint problem and heat expansion is causing problems.
IMHO not worth the repair.
Posted on Oct 03, 2009
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
JVC 32", 11 years old. flashes from picture to
after 4 or 5 yrs (depending on usuage ) in some TVs on mainboard & CRT tube's circuit board at some soldering joints cracks develops ... then due to loose contact TV behaves as you have described ........ when you are hitting that lightly on its side then these cracks at soldering joints are getting connected temporarly & for few seconds or minutes you are getting normal picture ....... so solution is most of the soldering joints on mainboard & on CRT circuit board has to be resoldered ....... only good tv service engineer can do this without shorting joints or damaging components..... so in your place contact few TV service engineers & ask them how much they will charge for resoldering joints on mainboard & crt tube's circuit board ......
Sep 05, 2011 | JVC Televison & Video
MY 35IN COME ON PICTURE AND EVERYTHING WAIT 10 SECONDS AND GOES OFF 35IN TUBE ABOUT 15 YEARS OLD
There is likely something wrong with the tube itself. It could be a short that is only there when the line warms up (10 seconds is plenty considering the amount of power that runs through it) or the CRT has a crack.
If you want to continue with this type of TV there are quite a few reliable TV repair companies in almost every mid to large town around the US. If you don't want to invest in repairing a 15 year old TV (not a bad life span for electronics by the way) then you could very likely find a 32"-37" LCD TV at your local electronic store that is reasonably priced.
May 23, 2011 | RCA Televison & Video
Hello, my westinghouse tv has sound but no picture. when the tv is turned on, the pic comes on for a second then goes away. tv is 3 yrs old
You have 1 or more bad lamps in your display panel. You can get replacement lamps, but there is a lot going on to change them. If you are not experienced in electronics, I would suggest you let a service provider fix it, or invest in a new set.
Apr 04, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv comes on and soon as it warms up picture goes goes black
Most likely this is caused by the failure of the inverter for the high voltage required by the backlight, 2nd most likely is the failure of the fluorescent backlight itself.
Aug 28, 2009 | Insignia IS-LCDTV32 32 in. Television
TV doesn't turn on. Insignia 32LCD
check the power supply boards apply fresh solder also apply fresh solder to inverter board. scan budged capacitors from secondary power supply.
Jun 04, 2009 | Insignia IS-LCDTV32 32 in. Television
Horinzontal white line with sound
vertical collapse. usually not to expensive to fix.
Jun 02, 2009 | Toshiba 32A33 32" TV
Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Dec 07, 2007 | JVC LT-32X576 32 in. LCD Television
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
