Question about Canon Pixma iP4500 InkJet Printer
My Canon Pixma iP4500 prints with streaks across the page in exactly the same places each time. I've tried deep cleaning but to no avail
  • Canon Master
  • 19,396 Answers
Hi.
Vertical streaks are either caused by ink inside the printer or by a defective or dirty print head. The deep cleaning procedure can clean the printhead, but won't clean dried ink that can still leave streaks..
To start, the printer must be taken apart to check if there is ink inside , and eventually clean it manually. Ink inside the printer is the most common cause for this problem. The ink carriage must be removed and soaked into isopropyl alcohol. If that does not fix the problem, then the print head must be replaced.
Regards.
Posted on Oct 03, 2009
    President:
  • 2,306 Answers
You DON'T soak these printheads in alcohol, all of Canon inks are water soluble...Also those streaks are most likely caused by a dirty encoder strip which can be cleaned with a water dampened Q-tip gently.
Posted on Oct 13, 2009
My pictures all seem to print with a yellowish / orange tint; they also seem brighter than on the screen.
Hy, this is a clasic case. you need to replace the printhead. I know this sounds drastic but this is the only way. BTW, I service and sell Canon products and have seen this many times.
May 25, 2012 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer problem: The printer seems to be working ok (no errors or warnings) and it prints documents well but is leaving a black streak on the underside of each page. I have tried...
Use warm water and a lint free cloth and clean all the ink around the cartridge area. I f that doesn't help I would try a new (not remanufactured) ink cartridge.
Jun 28, 2017 | Canon Pixma iP4500 InkJet Printer
All nozzles are fine except the yellow which does not print out at all in the test. I've cleaned and deep cleaned to no avail
Try flushing the yellow channel with cleaner with syringe. The cleaning function will not dislodge a blockage if it is severe. You will have to recharge the channel with yellow afterwards. You can probably do this with a refill kit.
Apr 09, 2010 | Canon Pixma iP4500 InkJet Printer
Ink on back
I take this printer is not under warranty, have your tried rubbing alcohol and cutips, works for me sometimes.
Nov 09, 2009 | Canon Pixma MP950 All-In-One InkJet...
Cyan doesn't print.
You should stop wasting ink on deep cleans, The most likely problem is the printhead.
QY6-0075-000 around $60.00
Aug 27, 2009 | Canon Pixma iP4500 InkJet Printer
A horizontal line appears on prints every 9/32 of an inch, especially on lighter prints
The following a step by step instructions for the printer issue:
Confirm the ink tank(s) are properly installed
Perform print head alignment
Perform Print Head Cleaning - iP4500
If the prints are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleaning or print head deep cleaning. Also, you can check the cleaning results by printing the Nozzle Check Pattern after cleaning.
Remove tape from the ink tank and make sure the air hole is clear
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon Pixma iP4500 InkJet Printer
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon MP160 leaving streaks
Normal 0 This has fixed a number of printers and worth a try
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP4500 InkJet Printer Logo
145 people viewed this question
old marine
old marine
