Question about Belling 24 in. IDW603 Built-in Dishwasher
Belling dishwasher IDW604
Only 1 year old door will not close and cannot set program even tough lights are working
  • 1 more comment
  • Anonymous Jan 07, 2008
    Exactly same problem door not closing lights on but will not accept a programme
  • Anonymous Feb 19, 2008
    1. take out the dishwasher u will c a the clip u can loosen the nut and pull out th clip that holds the door closed and then tie-ned the nut
  • davymacs1 May 26, 2009
    the door won't close. the machine will operate even if door is open. can you buy the clip that holds the door closed
    Problem Solver:
  • 7 Answers
There is a small plastic catch in the door side of lock which loks arround the bar on the washer side of the lock somtimes it stays in you can click it out with a knife or simillar sould work fine after that
Posted on Aug 01, 2009
Only washes top rack as if on half load. Bottom spinner does not get any water. not spinning even though loose??????
Posted on Jan 04, 2010
My only suggestion is dont buy another Belling. I have the same problem. This is after god knows how many other faults in its first 12 months.
Posted on Jun 22, 2008
When i swithch on the dishwasher it fills with water and then nothing the fault reading on the programme coun ter inside top of door rwads E3 please help
Posted on Jul 24, 2010
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Feb 10, 2015 | GE Dishwashers
The program selector is not functioning and the door will not close properly. are they related and how do i fix, tks
Hi.
If the door does not close properly, the door switch may not close contact to timer circuit, and the machine may not do the cycle for this reason. Additionally, a short in the door switch wiring harness may jam the control module.
Before checking control module have a look at the door switch and at the wiring harness inside the door.
Regards.
Ginko.
Mar 21, 2011 | Belling 24 in. IDW603 Built-in Dishwasher
I have model # FDB431LFCO My house is 2 years old.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Nov 20, 2009 | Frigidaire Dishwashers
Belling BEL-CJ/SS25 microwave
My Belling BEL-CJ/SS25 Microwave / oven / grill has recently developed a problem. Every time I close the door the turntable starts rotating, even when I'm not using it. It doesn't make a noise, and doesn't seem to be going into any cooking setting, and the light doesn't come on, but it turns until I open the door, when the light comes on and the turntable stops turning. This has only recently started happening, and nothing else seems to be wrong with it, Is this safe or should I get rid of it and buy a new one. The guarantee has expired so repair may be cost prohibitive.
Sep 04, 2009 | Microwave Ovens
Does not start. Cannot change programs
What is the manufacturer and model number of your dishwasher?
Approximately how many years old is it?
Are you saying the water never enters the dishwasher, even on the one program that you have?
Apr 11, 2009 | Dishwashers
Belling integrated dishwasher not working properly
are you sure it is the board at fault, not justv the door catch? (as the door wont open). If the dishwasher believes it has just finished a cycle and the door has not yet been opened it will not let you change the program.
I had this same problem so I hooked an allen key around the back of the white door catch and pulled it into the unlocked position with a pair of pliers. Has worked fine since but every now and then the catch will pop back into the locked position when the door is opened.
Nov 25, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Electicity going to dishwasher but when program dial turned it doesnt start program even though its switched on and door closed
small amount of water at bottom of dishwasher, electricity is going to the unit no breakers are blown, no light nothing responding on dishwasher
Sep 03, 2008 | Kenmore 16872 Built-in Dishwasher
My belling dishwasher wont start, the lights are on but when I press programme the red light no longer skips along the options , it simply doesnt appear.
Hi just trying to solve a similar problem. My machine would turn on but would not fill. It could be that your cold water filter is blocked. If no or reduced water pressure then the machine will not operate correctly. Take off back panel and you should see the filter assembly. GIve this a clean and see what happens.
We have 14 of these dishwashers and so far they have all proven to be very reliable machines. This is the first issue in 4 years.
Paul
Aug 12, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Belling BE601
reset the display to -.
if there's a number there it's the length of time later it will start at.
both the start and the program have to be selected together..........but you also have to reset it after the last program
Apr 01, 2008 | Dishwashers
Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Jun 26, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Belling 24 in. IDW603 Built-in Dishwasher Logo
2,387 people viewed this question
Top Belling Dishwashers Experts
Kamil Owsianiecki
Level 1 Expert
Oloyede Monsuru
Are you a Belling Dishwasher Expert? Answer questions, earn points and help others
