Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
I have a 455 Rancher. 3 years old. Once the saw
I have a 455 Rancher. 3 years old. Once the saw gets hot the power starts to fluxuate, then it will stop altogether. i have replaced the fuel filter, spark plu & air cleaner. I thought that their was a fuel problem so I weighted the fuel line to keep it own in the gas. Problem persists, even with a full tank of fuel, any suggestions
4 Suggested Answers
SOURCE: Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
Posted on May 31, 2009
philwalker78
  • 608 Answers
SOURCE: Hello I have a 455 Rancher
Hi, bring the hi speed mixture screw out approximately one eighth of a turn and retry. Hope this helps, regards Phil.
Posted on Jun 24, 2011
  • 2239 Answers
SOURCE: I have the 455 rancher and when I start the saw I
Before you do anything else i think you need to check the engine is mechanically sound, remove the muffler, take a look at the piston skirt through the open port, any signs of scuffing on the piston and it will require removing the cylinder to assess the damage, they are x torq engines, due to the way the air ports work they are quite prone to carboning in the piston rings, make sure it has plenty of compression.
Posted on Aug 21, 2011
Huskavarna 455 rancher with pplug keeps popping out
This is the de compression button, it should be pushed in every time you start the saw, it makes it easier for you to start the saw and reduces the stress and wear on the starter components, it will automatically pop out when the saw starts.
Dec 08, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Started 455 rancher after setting for about a month. always used stabil in fuel. started with choke on and then turned off choke once saw was running. the saw seemed to be stuck in high idle and would take...
This sounds like the throttle spindle sticking, or the cable sticking, if you remove the top cover and air filter, then push the throttle spindlefully back to the stop screw with your finger, then try again, the spindle may be a little gummed up.
Mar 18, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
, No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 10, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
What size file to sharpen chain for 55 rancher
It depends on the chain you have installed on the chainsaw. You can look at the numbers stamped on the drive link side of the cutting chain and it should have a 2 digit number that correlates to the size.
The factory chain supplied with the #455 rancher was a .325" pitch 3/8" chain.
Here's a link to the specs for your saw with some useful info
http://www.husqvarna.com/us/homeowner/products/sawing/chainsaws/455-rancher/#specifications
Hope you found this very helpful and best regards!
Aug 06, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I am getting fire on my 455 rancher BUT IT WILL NOT START
you need turn off you choke one's its fired up... otherwise it will flood the saw with too much fuel...
Aug 05, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
298 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
