Question about Fuji FinePix 4900 Zoom Digital Camera
What do I do if the digital camera keeps switching on and off? Works fine when on AC adapter, only happens when it,s on battery power. Replaced battery with new one, no help... Thanks in advance Charlie
  • 32 Answers
Check to make sure that the batteries are rated with the correct current.
Check to make sure that the batteries are installed in the proper direction!
Sounds like one (or both) may be the problem.
Posted on Oct 03, 2009
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
Camera will not power on
ok you have to check the bettery terminal and the power switch, maybe you have lost contact in your unit.
Oct 08, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Install new battery and sd card and cut it on and it when it come it goes right back off
Be sure to charge the battery first. New batteries are usually not charged when shipped (fire hazard).
does the camera work with the AC power adapter? If it works fine with the ac power adapter the problem is most likely the battery. Not charged or bad.
Jan 11, 2011 | Jazz DV-179 Digital Camera
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
Try removing batt and use ac adapter alone. Check if laptop works fine also check if LED flickers still.
Try removing ac adapter and use battery alone and check if batt flickers as well.
If flickering only happens when both are connected or vice versa try this first. Update the BIOS for your laptop. Download the BIOS update from http;//support.dell.com
Oct 22, 2009 | Dell Inspiron 6000 Notebook
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
FinePix S9000
hi, This is actually a very good camera.Did you insert the batteries in reverse accidently?? this seems to be a problem with the switching circuit from battery and power adapter.. did you keep the camera with batteries for a long time with out use?? U can give it to the nearest service to get the circuit checked. all the best my friend.. sreejith
Jun 20, 2007 | Fuji FinePix S9000 Zoom Digital Camera
No Power
Looks like the Cann has died of Neglect - throw it away- repair will be uneconomic.
Jun 14, 2007 | Canon PowerShot A60 Digital Camera
Fuji FinePix 4900 Zoom Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
