Question about HP LaserJet 3330MFP All-In-One Printer
Cancel light stays on and scanner warming stays on
WHY DOES THE SCANNER LIGHT STAY ON?
Depending on the machine it may require the scanner light to stay on to minimise warm up time when using the scanner.
Sep 06, 2014 | Brother MFC 9700 All-In-One Laser Printer
Fail to initializing
The fail to initialize is typically a problem with the document scanner...but not always. here is a quick test you can try. Turn the unit off then power it on again. Slightly lift the copy lid as the unit goes through warm up mode...pay attention to the light color emitting form the scammer. it starts to blink red, then changes to a bright white IF the scanner is working properly. IF the scanner is NOT working properly the scanner stays RED during the warm up.
Nov 26, 2013 | HP LaserJet Pro M1212nf MFP -...
Light engine stay on when water temperature needle indicator is in the middle, engine works OK, and car too.
The check engine light comes on and stays on when a problem is detected by the self diagnosis system of your vehicle. Generally, the problem is in the emissions or something that is affecting the effectiveness of the emissions, but other causes can trigger the light to come on, too. To determine the cause, the vehicle will need to be taken to AutoZone or a shop that has an OBD2 scanner, or for 1995 and earlier models, an OBD1 scanner, While a scanner will not give you the magic answer, it will give you a code that narrows down the problem area.
A flashing check engine light is an indication of a severe misfire or problem that is likely to harm your engine. Immediate diagnosis and service is needed.
Some specific causes for the light to be on are:
Gas cap left off, not tightened, not installed correctly, or needs to be replaced
02 sensor
Engine misfire - error might clear itself after 3 complete warm-up cycles; not restarts, but warm-ups
At start up for a bulb check - Should not stay on
Problem in the emission system, including clogged exhaust or the catalytic converter not functioning properly
Dirty/clogged air filter
Dirty MAF sensor
There are pages and pages of items that can cause a check engine light to come on. Having it checked with a scan tool will narrow down the problem area.
Nov 01, 2010 | 1997 Toyota Tercel
Hp fax model 3330 is broken . At first it was very slow to warm up bulb and finally it stopped working all together and the screen says scanner error power on - off. The cancel light is blinking and...
You are correct with your diagnostics, he problem is caused by dirty optics. The mirrors in the scanner have dust, lint or smoke on them. When the scanner powers up it tries to calibrate itself and waits for the bulb to warm up so the light output gets to a certain level. With the dirty optics the scanner never gets enough light so it thinks the scanner is still warming up and so it waits for the light to get brighter. After a few minutes of waiting and not getting the correct level of light it gives the power off message. We have a dis-assembly and cleaning guide with step by step instructions posted on our web site at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ This procedure takes about 30 minutes to complete but it should et you back going again.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 15, 2010 | HP LaserJet 3330 All-In-One Printer
Engine light on
02 sensor
Dirty MAF sensor
Jan 08, 2010 | 2007 Ford Freestar Limited Minivan
Hp laser jet 3330 will not reset with acquired instructions and bulb warming message stays on.......i've tried to unplug unit....stays the same. cancel button also stays lit
You need to take apart the top and clean the scanner bulb and mirrors, if cleaning does not help then you need a new scan assembly. Usually costs more than a new machine.
Jul 14, 2009 | HP LaserJet 3330 All-In-One Printer
Hp psc 2110 copy problem stuck warming up & scanner bar get stuck
The scanner carret belt might be too loose, so the printer cannot pass through the self-test. Try tightening it a little bit. Also you have to either repair the nobs or solder it.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Scanner light stays on
I have the same problem. I chatted with HP customer care for an hour but it can't be fixed. The only thing you can do now is set the power saver mode to 2 hours, so bulb will turn off in 2 hours. Only way to minimum power consume.
Mar 21, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3330MFP All-In-One Printer Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
